Short story shorter. Dropping front driveshaft to replace worn spiders. 6 of the 8 bolts came out easy. I rounded the heads on the other two (my bad). One is on diff side and one on transfer side.
Any advice on best way to remove? Any mistakes I should avoid? Don't want to damage the bolt on the transfer side.
Sprayed them again and will try again in the morning with more patience.
Internet options found:
-hammer and chisel to unscrew
-impact spiral bolt remover
-heat with oxy-acetylene
I assume you can buy new nuts and bolts from Toyota?
