Front Axle issues.......
Texas
New to me 2005 with 327K miles with aftermarket axles.
Major front end clunk when shifting F-N-R and after slack from coasting. Yes I have greased the front and rear DS and slip yokes. I can see the slop in the CVs when I move the rotors back and forth both on the wheel hub side and diff side. Has anyone else had this issue? What was the fix? Thanks for the input
- Good Napa premiums 139/ea
- OEM rebuilt 109+ 75 core
- New OEM 480/ea!!! ouch.
Take a look at the below videos. Very common for aftermarket, and OEM, axles to wear out the hub flange or vice-versa.
Another commonly addressed issue is the front differential mounts. You can search for that in this forum.
I personally had the same symptoms as you and the cause was a worn out aftermarket axle and flange. I replaced with new OEM. OEM rebuilt is a great option as it comes with a warranty and is much cheaper. I have a reman installed on the other side.
That is exactly what mine is doing. What are all the parts I need to replace to fix it. Im doing all the work but want to use the correct parts and do it right. What is best source? Junkyards new OEM I don't see hub flanges on Rockauto and want to replace everything the first time. I hate doing things twice.
Thanks fellas!!
Thanks fellas!!
Lot's of reports of similar symptoms with very mixed bag of results. Check out the official clunk/thunk thread if you want to get depressed. Some people have success with various repairs ( CV / Hub Flange / Front diff bushings, etc. ) and others just throw parts at it until they're broke to realize the play is coming from inside the diffs or transfer case. I'm one of the ones who threw a s*** load of parts at it , nothing helped, and I realized I don't care about the clunk. Been 100k+ miles of it, not getting any worse, life goes on.
The OFFICIAL clunk/thunk driveshaft thread - https://forum.ih8mud.com/threads/the-official-clunk-thunk-driveshaft-thread.401590/
Just one guys opinion but I truly think if you lock the diff up, and the clunk goes away, then it's an internal problem. If you lock it up and it goes away I don't see how something like a front diff bushing or CV / hub flange play could be the issue. If anything you think it would get worse.
Thanks fellas!!
i got parts from mcgeorge toyota online
Hub flange is cheapest on Partsouq. The parts will ship from the UAE, but they will arrive in about 5 days usually.
If you want to support a US business, call Cruiser Teq | Land Cruiser Specialists Powered by Cruiser Outfitters - https://cruiserteq.com/ . Cruiser Outfitters will help you with advice about any parts purchase and is 100% some of the nicest crew you will ever meet.
I am going to redirect you to the clunk thread for most of the info, but I will add that cheap aftermarket front drive shafts only have 3 bearings vs the Toyota having 6. It makes the part less durable off road. Most people will never wheel their truck hard enough for this to be an issue though.
But most on MUD will "lift" their 100, for which the tripod CV joints on aftermarket axles will quickly become problematic, even if the truck is never offroaded, whereas the rzeppa CV joints on OEM axles will generally be fine.
I hadn't thought about that. Great point.
Yeah. Even put the rig on jack-stands, they can.
I wanted to follow up with the results. It was mostly the front lower Differential bushing causing most of my issue. I replaced it with the OEM bushing without the front diff cover and top pad. It seriously only took a total of about 20 minutes to do the whole job start to finish and that included searching for my air chisel. 95% of the noises are gone. I am going to replace LCA bushings and steering rack but all this can wait a while.
Thanks everyone for the help.
Did you just do this fix? Report back after a few hundred miles if possible, I'm really curious if this solved your clunk completely, especially since you noted you have some slop in your CV and hub flanges.
It fixed most of the issue. The bushing was completely worn out and missing most of the rubber. It still needs a bit of work to be 100% but certainly much better.
