Fried a 1FZ-FE
My brother fried his 1FZ-FE last night. He has a 97. We have an older 93 with a 1FZ-FE and need to know what the interchangability is between these 2 years. I know that there was the switch to OBD-2, but as far as just swapping the engine out and leaving his accessories and wiring harness, will there be a big problem?
dumbass let it overheat till it made a ticking noise and shut off when he put it in park. He poured coolant into it after than and said it all just poured out the bottom of the engine somewhere. probably ran it dry for a few hours, he was on a 500 mile trip
Might be a cracked block from pooring cool antifreeze into a hot motor.
no, it was leaking badly before this happened and before it overheated. I think a hose got cut from something rubbing on it, and got worse the longer he drove.
I'm sure the engine is rebuildable, i'm just not sure that it's cost effective. Hopefully something works out.
Anyway, has anyone done this swap? I am looking at just swapping the block out, his car will keep all the same electronics and accessories.
There are different electronics and emissions. It can be done, but the easiest bolt in path is gonna be sticking with a 95-97 motor.
There was a recent thread where a new, surprised owner discovered that he had an earlier 1FZ in his 95-97, OBD-II truck.
The issue with putting an older engine into the truck is the crank sensor. The earlier ones did not have one. To put that onto an earlier engine you need to swap the upper oil pan and various bits on the crank itself so the index ring is in there. That means pulling the front of the engine off which means yanking the head.
I'd look real hard at repairing the existing engine before modding an early one.
Thanks for the information. That's all I need. The original goal was to rip the engine out, swap it, and be done with it by christmas. Looks like this won't happen. Perhaps a rebuild is in order. What have people seen as far as a basic rebuild cost for these engines? There may be more on top of that due to the overheat issue, but generally, what do people see?
I agree - we will retrieve it and remove the engine to see what is broken - if it takes a while before he gets his ride back then tough - anyone who fries an engine after being told twice to check his coolant deserves to walk a while. I can get the rebuild kit for a little over $200.
budget about 600 to 800 for misc replacements while you in there and misc head work (if necessary)
replace the water pump, hoses (all of em), and other stuff (i'm sure others can fill in here)
i would look at what really happened (hose blew or head gasket)
if just a hose, replace it and the thermostat. check vitals like oil and coolant for cross contamination.
if head gasket blew, remove the head get a gasket kit, new head bolts, and have the head checked for straightness.
put it back together and enjoy!
P.S. in my experience it takes alot to actually kill the entire 1fz-fe. like everything else toyota they are so overbuilt.
Update: Tore the engine out, BOY WHAT A BEAR!! I am used to working on small high performance rotary engines, so this sort of thing is a little different to me. I am still impressed at Toyota's quality of build on this car, although they did not make it very easy to service (i.e. Wiring harness secured every 6 inches - great for reliability but horrible for removal) - but it ain't supposed to break!!
The source of the leak has not yet been found. There was no cross contamination between the oil and the coolant, although there was some oil that seemed to leak from the head to the outside.
I will have the radiator pressure checked and will replace all the hoses, headgasket, bearings, valve seals, gaskets on the outside, and rings. If there is anything else warranting replacement, it will be done. I will check the bore with some bore gages, and will send to a machine shop to ensure the head is flat; it may need machining.
I hope he didn't melt a piston, the dealership said "there was no compression." I could not verify this, as my only compression gage is set up for a rotary engine and has the schrader valve removed.
Also, on the trip back, we towed with a 95 T-100 with a 5VZ-FE. It towed well, lacked a little power, but nonetheless, got it home. I was probably at wide open throttle for a good 25-30% of the way back (drove through the hills of southern ohio and norther West virginia). And we had an ice storm on the last 20 miles which took about 2 hours to get home safely (almost saw a semi jack knife and eat it!). I love Toyotas!!
Here's my 80 series. My brother should have easily obtained this many miles with proper maintenance, like my dad did.
Here's my brother's rig, ready to get the engine fixed.
I love rotary engines!
STOCK rotary oil cooler (keep in mind this is a 1.3 liter engine - like a 2.6 liter piston engine)
Removing the grill for engine removal
Twin belt water pump drive. Way to go, toyota!!
Removing the ECU Connectors
Engine bay - ready to come out???
No, just kidding, had to get these pesky automatic transmission wires off. Stupid autos.
Finally! 18 hours of work with 2 people busting ass. Thank you, again, Nate!
