Fried a 1FZ-FE
That's one big torque converter and transmission for 212 hp and 275 lb feet of torque. Should have lastet forever!
Before
After
Thats a lot of flywheel bolts for the power/torque output!
Therefore, I like it.
Gear drive power steering pump? Every time we take more stuff off this engine, the more I respect the engineering that went into it. WOW!
All but 1 bolt came off, so we tried this, which didn't work
And neither did this:
So, I had to do this.
Might I add, this was incredibly hard to weld without welding to the actual flywheel. Welding a socket to a bolt is not an ideal scenario, two very different metals with no preparation (probably some oil and grease on both)
Leverage required to remove that pesky flywheel bolt
Autozone says this...........
Will easily be supported by this......
Liars! But it will support my 13b (rotary). I'll keep it.
Just look at that ribbing on the bellhousing side of the block! WOW! strong design.
Coming soon: teardown and rebuild pics
Might I add:
Special thanks to Nate Frame!!!
I'm really interested to hear what the actual cause of the failure was. I don't think I'd go through tearing a drivetrain that huge out of a truck unless I was sure that it was absolutely necessary. Regardless, the pics are great... keep 'em coming, and let us know what the actual failure ends up being and what kind of damage ensued. Cheers.
Thanks for the pictures. If that's a '97 then that transmission is the "weak" A343F as opposed to the A442 that you had in the '93.
Looks like you had some fun... I am at about the same stage, 10 hrs to pull the engine split up in two days. I had left the tranny bolted in mine but dropped the tranny mount crossmember to access the top two tranny to engine bolts then refastened. The two problems that I had were the exhaust pipes hitting the engine bellhousing and the tranny cooler hardlines doing the same on the opposite side... I also unbolted the AC compressor from the block so no lines were disconnected, (AC works GREAT and didn't want to chance buggering it up). Had to buy MORE extensions for the sockets and find some good sized pipes for breaker bar extensions...
My engine stand DEFINITELY did not like a fully dressed 1FZ on it, I previously had a Olds 455 mounted beforehand in which I had to add some reinforcement. Your engine stand looks to be better in that department. My engine stand is a #1250lb chinese job: http://www.truckcustomizers.com/images/prods/KEY/K4KEY1128.3.jpg I highly recommend a different design!
One flexplate bolt stripped out on us as well, some craftsman bolt extractors and a hammer with a impact worked flawlessly. (socket type with the reverse spline that grips the head of the bolt) These things saved me more than once! I also used a 2Ton AFF moel 582 engine leveler to help, I had never used one but now I am a true believer that it does make things a whole lot easier...
Our '93 had a severe knock on #4, pulled the head and cylinder and gasket both look good to our relief. The culprit is a bearing or wrist pin, both easily replaceable without machine work... YAY!!!! Next step is to remove the timing chain cover and oil pan, rods/pistons, crank... New bearings and maybe new pistons/rings with gaskets seals, cam followers should finish things up but won't know for sure until it's torn all the way down. The truck has 286k miles on it and the valve adjustments were too loose and caused the cam lobes to hit the followers without rotating them which wears things extremely FAST, MAKES SURE YOUR VALVES ARE ADJUSTED!!!
Is there something with the 1fz that makes you have to tear out the lights and disconnect the trans before you yank it? The 3fe comes out nicely without having to separate the trans, transfer case or tear apart the entire front of the cruiser.
On the stuck flywheel bolt, put a few more back in, then try to get it out. A combination of inserting a few more, heat, and soaking with penetrating oil may have prevented having to weld a socket on.
I admire you for taking on the project. Having done it twice, albeit on a 3fe, I would probably not do it a 3rd time.
I feel very strongly that the entire powertrain should be pulled together. I say this because there is a vast number of wires and lines that go back to the auto trans, and they were next to impossible to remove without breaking, and upon reassembly I dont think it would be very easy to put it back like factory. There is no room around the back of the engine to work on the wiring for the trans and the cooler lines.
Why mess around with the engine trans alignment process, when in an extra half hour I can have it on the floor as well, then throw the hole thing back in.
Just my 2 cents...
To anyone who attempts an engine pull in an 80, I would recommend pulling the hole thing at once, it would have shortened the time we spent on this job by probally 6 hours.
:bang:
Just my 2 cents...
:bang:
Nate is right, we should have taken it all out at once, although I'm not quite sure how we would have done that with a standard cherry picker. I might add that we didnt really break any connectors at all, but it was quite difficult.
It's doable. I've pulled complete combos and that's with my 30 year old picker. Balance bar makes it easier so that you can adjust the positioning as you pull. Removing center section of the rad support is a must which is why the headlights are pulled I think.
Nice weld job on the stubborn flywheel bolt. Did you use an impact on that bolt? Did the head round before the vice grips? It should have come off with a good impact and proper socket.
that's the way its going back in, so I'll have to find my old balance beam.
It rounded with a very good impact and a nice Wright tool socket. The vice grips and heat were an after-the-fact failed attempt. I think if I had left some other bolts on and just cracked them loose, I would have had better success. Nonetheless, the bolt/socket welded combination are now proudly on display on the mantle.:D
Ah well, you got to showcase your skills!
Agreed, nice collection of skills and equipment to help ease things when problems arise. When we pulled our engine we left the condenser and radiator support panel, so clearance would have been an issue with the tranny attached. (we really didn't want to open up the AC lines) The tranny will probly be pulled anyways since I want to go through the wiring harness and plugs to wrap it/shrink tube it afterwards for many more years of service. The electrical plugs were pretty easy to disconnect from the tranny other than getting a face full of dirt and disintegrated foam bits.
Another problem that we had was a stripped exhaust manifold nut, 12 point sockets are not ideal to use for TIGHT fasteners and didn't notice it until I stripped it. I used a 4" grinder which DOA'd and a cut off tool to grind the nut/stud down until everything popped off.
The intake will be gone through while on the bench :) maybe a few things relocated to make maintenance easier in the future... :)
The 3fe must be different. On my pulls, the headlights stayed in, as did the other trim surrounding them. The rad, condenser, and the rest of the center section was removed. Bumper stayed as well. There are hooks, at least on the A440, for chains and if you set them right, it will come out at an angle just fine. Of course you have to ride a jack under the tail end of the transfer case up to the front axle, then raise the hoist, lower it, reset the chains, etc... I didn't use a leveler, and not having one wasn't much trouble, but it would have helped. Charging the a/c was the easiest part, but I do a/c work.
Kudos:cheers:
I'm waiting to bring it to MI. I don't want to get into the motor until I have everything situated.
Nice pictures, and nice welding job too. :clap:
But I sure hope it wasn't just the pesky heater hose that needed to be replaced. :D
