- Thread starter
- #81
Spressomon,
help me to understand what the main benefits was over the Bilstein set up? I belive it is travel and valving correct?
What did all this cost and and if I wanted to do it, what should I look out for?
Thanks for the pics!
I assume you are referring to the Bilstein 5100 or similar and not the 7100/9100 correct?
The Fox shocks are completely tunable and rebuildable. Having said that they are a mono tube design. From what I gathered from Christo a twin tube shock design (OME, Bilstein non-7100/9100) maybe better for street use. However my desire is to focus the performance for more off-road. The Fox shocks as I have them set right now work very very well off-road. However they need additional dampening for ideal street use. I am hoping the easy to adjust manual clicker compression valve adjuster will allow me to firm it up for on-road use and when I am pulling the trailer. The other benefit from this shock design with the remote can is no fade when blasting over washboard!
Not cheap...the shocks w/o the adjusters are $180-$200 each. Don't yet know how much the adjustable compression tops will add (will know within the next few days). Then custom upper front mounts (these are actually fairly easy to fab). And custom upper and lower rear mounts.
Additonally...it appears some shock warehouses actually order Fox shocks as sort of a custom stocked item that you can't normally obtain directly from Fox...or at least Fox doesn't provide much assistance unless you have their part numbers. For instance Fox apparently offers a 2" non-coilover, remote res shock for a Jeep model that features a beefy post type upper mount like the stock LC...I just haven't had time to do the research to see if they offer this set-up in a 6.5" front travel and 10" rear travel (my shocks feature the more traditional eye mount for upper and lower mounts).
As soon as the rear mounts are redone and I have the body lift installed I plan to provide all the details.
