ARCHIVE Forge Specialties: What are we working on?
This ends up going into the truck like a ship in a bottle...
...and because a 5.3L can't have the engine bay all to itself, we're building a bracket to house an:
ARB Dual Compressor
ARB Air Manifold
Blue Sea Fuseblock
Helton Heat Exchanger
Factory Cruiser Control Unit
This little Bundle of Joy will end up sitting in one of the few available underhood spaces, on the passenger fender.
Are you guys coming to CMCC?
Hope so!!
Unfortunately, no. We've got way to much work. It's a good problem to have, but we were really wanting to make that one. I think the next events that we'll be able to get to are the Mid-Atlantic Overland Festival(Huntingdon, PA) in August and the Appalachian Rendezvous(Uwharrie, NC) in September.
We've carved out a little time on 8/8 for the "Beno Meet & Greet @ Kilroys" though.
...a very grimy and stripped down 5.3L. It's comical how much room there is in this engine bay with no accessories.
...and a squeaky clean 5.3L, after a visit to the machine shop for a refresh.
...starting to pile on the parts:
You guys do sick work.
...and what LS-powered Tacoma would be complete without a BMW power steering reservoir?
The elevated placement makes more sense once you see how insanely full this engine bay is.
We had a customer with a Foxwing on his 80:
The customer wanted to utilize some clip-on LED light bars to illuminate the underside for camping. This required several power outlets that would be reliably weatherproof. Instead of running external power all over the back of the truck, we decided to do an extension cord setup of sorts.
We started with some weatherproof molex connectors:
...and ran power from the rear of the vehicle, to the back of the swingouts:
The routing was a bit tricky to make sure that everything stayed tucked out of the way but didn't get pinched:
Each swingout ended up with a female molex connector:
To keep everything weathertight, when not in use, a dummy plug was made from a male molex connector.
The male plug is made into a tether:
The tether and dummy male connector, allow for a weathertight seal that tucks up onto the swingout. It's out of the way, but still accessible whether the swingout is open or closed.
The next step involves some project boxes with 14lb magnets epoxied to the bottom:
...add a couple of 12v outlets and some spiral power cord:
...and you end up with magnetic 12v extension cords.
The magnets are actually strong enough that you can stretch these things halfway down the truck(not pictured):
...knocking out some sliders for a 2012 Tacoma:
It all starts with some 2x3 .25 wall.
...welding on the end caps and .120 outer rail.
...fabbing up some legs.
...satin black paint, for easy touch up...since they're sliders...
