Nay, not to hijack, but do you know if these are oe Toyota parts, real Koyo joints, or aftermarket joints that are similar to Koyo/Toyota design? Your statement implies parts bought from Toyota.
There is a huge difference between aftermarket parts that are like the Toyota / Koyo design and real Toyota parts. BTDT
AZLX450,
You could have condensed your entire post with:
"I love Frankie's suspension", and "I have really deep pockets, unlike most of you peasants".
Hey, just a thought for future reference.
My next problem was finding someone to put the lift kit on for me. I have very little wrenching ability or inclination but I do know a thing or two about making money - so I wanted to pay someone else to do it.
lol...this was by far my favorite part...
is this bill gates in disguise?
AZLX450,
You guys realize that for a lower lift with Frankie's springs you simply cut off a couple of wraps. I plan on doing this on my other truck which will be running 33s.
I'm shooting for a 2-2.5" lift and a 3* offset bushing.
Rick, given that Frankie's spring are non-linear, what end do you plan on sacrificing? i.e. the higher rate or lower rate end?
-KK
AZLX450,
you don't sacrifice anything. The springs are designed so that the top of the coils stack on themselves. Cutting wraps off of this stack changes the height. If you cut enough of them off you will need to go with a different length shock to make sure they are still captured under full droop.
Frankie has assured me that this approach will only change the height of the truck and not the load carrying or driving characteristics. And if I give him the dimensions of the shorter shock he can supply that as well.
Are the springs a linear rate, or progressive? If they're linear then you can cut coils and still have the same spring force, which is a function of the spring rate and displacement.
If they're progressive (non linear) you will change the spring force by cutting coils, as the spring rate is based on displacement of the spring. Depending on how much you cut, it could change the behavior of the spring. Pay attention to the next riced out primered Honda Civic that you see, because odds are he's cut his spring coils. Notice how poorly the body motions are controlled.
Cutting coils can also be dangerous stuff. Depending on the cutting method you risk weakening the spring, and it's very difficult to cut 4 springs by hand to the exact same length. Generally speaking, cutting springs is a bad idea.
What's the point of such tightly wound thick coils? Seems like they wouldn't unload much anyways under full droop, why not just supply user-selectable spacers and save costs on excess metal![]()
