Official ONSC member buying/selling thread (3 Viewers)
Wanted .... some 1FZ-FE EGR parts ....
Egr module and EGR valve.
Thanks
Rice
Vacuum Modulator is pretty cheap new IIRC but egr is discontinued...... think steve found a NOS on ebay though. Might have an old one to test with.
Looks like a "deal" for 1 million. Liability insurance should cost that much each year.
Hmm. Only shopped one place but vacuum mod was $85. Guessing there is a part out truck that might have them.
Thanks
Rice
@Rice unless you know for certain otherwise I would replace the VSV first. I replaced both EGR module and valve and still have the CEL which leaves the VSV the only thing I haven't changed. If only I would have heeded @jfz80 advice and done the VSV first:bang:
Gotcha. My 'memory' was it was much cheaper.
Ill drop an egr on your porch in the next hour
I believe my advice was resistor and relax ;)
VSV was swapped .... only the temp sensor, mod, and EGR are holdovers from the last motor. That's not to say VSV #2 isn't bad but since the old engine intake is sitting in the garage it would be no trouble to test the VSV from the old motor and see if it's healthy (This is to address an EGR code I was getting with the old motor and the new)
Gotcha, if I'm remembering correctly it's not the temp sensor VSV but the other one. The one directly under the intake.
Resistorance is futile... install the resistor, loop the vac lines on themselves, and plop a blockoff plate in (if its stuck open or partially open, if its closed, dont worry with the plate). call it a day. no sense in throwing new parts at something that will get yanked out in "insert semi monthly time span joke here"
were you able to look at your harness while the engine was out for any worn insulation? I've got some thermal tape you can use if you need it.
Was strongly considered. Current plan is to install the MAP-ECU engine management system that will be used with the turbo and run the engine N/A while the MAP-ECU is in learn mode. Objective is to use the N/A engine to get a base map and then install the turbo. For that I wanted to have an engine that wasn't trying to throw codes.
For sale, my M101A3 trailer. $750 firm for current ONSC, LCLC or UC members. Details and all pictures through the craigslist ad:
M101A3 Trailer with fiberglass sides, bows and canvas top
DIepQHP7Fb9iSgKslARN-dr4P41sv4xDiSFT6oQgBzc81uG-n-Eqc9ZGJrxX5iX1N3VvtC5heX2JERraRRpB_myQrfq-5-x_jt4ZhKmdu43QyB7DubeN98_NksPThp5tgmrx7Yr9Kv3GaZIJTb--2hMVzLa9UzqyBkVrmqp8sBxDkipP-6dLuollF8mODc3UrrfRVFoz0zUy0Z4GxjNcq3KZbGht26pWJ0vlKX2BzI6qjGwfeBZZm4EHky4wMTXCu9ec1yVZQOCJVYHH0w9cl_DeROifGLdJgee45rsNvMLxIg6avG3sSVpmWKbcs9dCkOwUM_QmI5yRpNQ7vbPswxjyivnmy_X27PSvLOi1ACzW4rHyQLlKvwv8M3tmDWELvrO6gCTXzfv6jOkJ5u71QmM5ZPy6hjc1XovYNePq-LjOLmULJn2RALn1-74SMPpG1sz7FjYg4Vp5ol1iBaZi9pX1R0OiuSz7Mv5fWWxloGHPTDWTBFTcSanuqUp3gVP506yH9lzOSG_4mKq7NoWBlIChr4FOJJDxekAukagdNbvwqSVN_TMX69aecNIG1JGAuSJDo1W-DJhBroIObm2QEV4MznQ3qGFnxfks_mefuXGKDgObAam6eg=w2530-h1898-no
Also wanted .... FZJ80 rear driveshaft.
Heres a long shot. Still doing some research but putting this out there early to see what may be available
Wanted: A343F transmission
non august-oct 97 build date
Preferred Serial number range-
97AE-07106 - 97H*-00001 or
97K*-99999 - end of production
Acceptable serial number range-
96JE-06161 And newer
@Roxx
@GLTHFJ60 --- did i just toss mike's 97 at the recycler?
@jfz80 Not sure about Specifics, Wagners in Durham has a trans from a 97 with 81k
