floor drain
Ride in VA now in NOVA
So I know that theres a hole in the floor under the tank but Im looking at puting in some extras for added drainage.
The big Q is does anybody know where I can get some sort of a locking plunger, cam, drum plug...
What Im looking for is something thats water tight but can be removed from the inside quickly, maybe a D-ring 1/4turn flushmount cam?!
There should be holes on the driver's and passenger sides floorpans for drainage. Perhaps you didn't see them because they already have plugs in them.
16, 18 and 19, depending on years
yup, my buddy used a boat drain locking plug, works great.........if you don't mind drilling a big hole in the tub
local ACE store has numerous bins filled with plugs and such, maybe one of those will work
There were some drain holes in the old tub but ive since then replaced just about 90% of the floor with new sheet. I dont mind cuting big holes in the floor for extra large drains cause i figure bigger is better. The hard part is finding a boat supply store in the mountains.
Anybody know of a good online distributer???
Thanks
i drilled a couple half inch holes and use grommits to plug them, i have one in the front close to where the roll cage is bolted down it seems like the water likes to run that way and then i have one near the back. im rhino lined so when it gets muddy inside i just break out the hose.
Thanks toyo I found that one earlier this week but have yet to find a better one. Tried making my own out of some pvc fittings but decided that i dont like em. Guess ill suck it up and order some. Insides getting the full Durabek coating so a black plug will look good.
Peace
