- Thread starter
- #121
Anyway, still measuring the front coil mounts, I could set it with 12.5” height coil without any body mods, but I want a bit more travel. At the end I set it to accommodate 15” height coil with minor body mods. Fyi, the shock travel only about 9”. And the actual suspension travel will be about 12,5”. So I should buy a longer shock, but at this point, I’ll just settle as it is. Just leave it for next project. This radius arm system with panhard suits me cos I want more comfort handling, easy to do with the available oem control arm.
For on road manner, the radius arm system is an upgrade from the leaf. Drawback is the flexibility and bind. So another upgrade would be a longer arm with shape that sits parallel with the frame, heim or johny joint, and maybe weld it to the inner frame. This might be my next project if I’m not satisfied with the current set up. If you want more hardcore I think the 3 links front and 4 links rear with coilover will be best. The rule should be the same more offroad flexibility, less onroad manner and vice versa.
8274 $1600. Factory Pto $1900. Hydraulic n/a.
