Fj80 experts please help
Pull the code by jumpering the diagnostic port in the engine. Did you replace your intake tube from the air filter box to throttle body? Because you have a 95-97 tube, which is longer, and if old may be cracked due to having to fit the longer tube in the space. Also take off your glove box and check inside that you have a ECM with part number 89661-60221.
I'm not too good mechanically with these cars but I have a snorkel installed if that makes any difference
Yes, you need the codes read. Not likely that injectors are the cause, because it wouldnt all of a sudden just start running fine again after 15 minutes. Check TPS, MAF and other sensors that control fuel delivery. Hopefully reading your code can point you in the right direction. Can also be the catalytic converters. Check to see if they are glowing red when it starts to run poorly.
Have you pulled a code? That would help. Even if the CEL is off, I believe you can pulled stored/past codes.
Pull the code and there is 2 knock sensors
I haven't ever heard any good things on refurbished vaf sensor? Maybe just go pull used one from somebody or junk yard and try that, you can also check your tps sensor with multi meter pretty easy
Honestly before buying this I called every possible junk yard or auto parts store nobody had it
Could it be that the connector is bad on it and I need to splice in a new pigtail?
Did you get a maf sensor? That is for obd2 trucks take pic of the sensor
What state are you in? Why did you replace yours in the first place?
Did you get a maf sensor? That is for obd2 trucks take pic of the sensor[/QUOT
Ok looks right why did you replace yours did you try to open it?
