I'm in Californian, and the reason I replaced it is because the first one went bad so I bought exactly another one according to the part number and it fired back up
Where in CA are you located. I'm in Fresno and can help. If the codes are pointing to the AF meter you need to start looking at it. When it goes into limp mode start by wiggling the wires for the AF meter then un plug the AF meter then plug it back in. See if it makes a difference.
Intermittent problems are ALMOST always electrical. I think youre heading down the right path. The '93 year had a known bad batch of ECU's so check your ECU part #. I believe there are only a handful of issues that will put the truck into limp mode, might want to dig up the list of those and start checking them off one by one, starting with the VAF.
I've had to repair a few harnesses at the TPS connector now. From vibrations the wires had severed themselves right at the connector. You might try and pull on the wires at that point and see if any of them are broken. They can break internally but still be help in place by the insulation.
You might have two problem, 1 being a bad air flow meter.
The connectors for the tps looked almost new but I'm not sure of the internal condition of it as far as the air flow meter I messaged the guy he agreed to replace my current one with another unit
It's not hard to put a new one on but you have to set it with multi meter, I would look over your harness like land take suggested also, the procedure for tps is in fsm
You can also set the tps using a timing light and it is more accurate. When the tps sees the throttle open the contacts it will advance timing at least 5 degrees if I'm not mistaken. Warm engine and look at the timing marks then adjust the tps so as soon as you start to open the throttle the timing jumps.
