Fj80 experts please help
California
im in dire need of help my land cruiser has been sitting in garage for past month because I can't figure out what's wrong with it. Couple weeks ago I posted a thread about my problem and everybody suggested that replacing my knock sensor should fix the problem, just yesterday I got my new OEM knock sensor and the problem still remains. Basically the car starts and drives fine for first 15mintues when all of sudden the check engine turns on and the car doesn't go over 20mph pressing accelerator doesn't do any thing. This thing lasts for good 5min or so before the check engine goes away and again it drives normal. Things that I had in my mind that could potentially cause the problem. Bad O2 sensor, injectors (will most likely send them to RC engineering in coming days). Recently changed all spark plugs and spark plug wires to OEM, please hit me with ideas on what my problem could be. It's a 1994 4.5
CEL goes off on its own? That doesn't sound right.
Is it flashing when it is on?
you can test the knock sensors, its in the FSM. maybe ECU issue? wiring harness at EGR or glovebox? i would get very familiar with the FSM and a multimeter.
Have you checked your CAT's. It could very well be your CAT is broken up on the inside. A piece falls and blocks exhaust and then you hit a bump and it moves. Also, Have you pulled the Codes and see what it the ECU is telling you is wrong?
Wrap your EGR, It costs $20 and can prevent a lot of headaches down the Road.
Everyone with 1FZ-FE should do it - known problem
Here is the info for the Wiring harness behind glovebox:
Quick Check
Another place to inspect engine wire harness
Great Looking Truck bye the Way!
Have not checked the cats but since it's OBD1 I actually got one code and it had to do with my keyless start alarm
Have you pulled a code? That would help. Even if the CEL is off, I believe you can pulled stored/past codes.
Pull the code by jumpering the diagnostic port in the engine. Did you replace your intake tube from the air filter box to throttle body? Because you have a 95-97 tube, which is longer, and if old may be cracked due to having to fit the longer tube in the space. Also take off your glove box and check inside that you have a ECM with part number 89661-60221.
Yes, you need the codes read. Not likely that injectors are the cause, because it wouldnt all of a sudden just start running fine again after 15 minutes. Check TPS, MAF and other sensors that control fuel delivery. Hopefully reading your code can point you in the right direction. Can also be the catalytic converters. Check to see if they are glowing red when it starts to run poorly.
