Fj62 EGR DELETE
Springville Utah
As some of you may have seen in a recent post of mine, I brother the EGR hose on my 3f. I will still need to smog the cruiser next year, but I need a temp solution to get me by. I was planning on ordering the man a fre EGR delete kit, but I saw it was for a 2f. Does anyone know if this is compatible with the 3fe? Is there a different solution that I should be aware of?
All that's needed is a cup plug for intake manifold and a threaded plug for exhaust manifold.
What size is the threaded plug on the manifold (M26x1.5 it looks)? When I did mine I ended up using a cup plug on the threaded fitting cuz I couldn't figure out the thread size, or a source.
From my build thread. I tapped it out to 3/4" NPT and threaded in a stainless plug.
The tutorials suggest plugging the hole in the exhaust with a 3/4" NPT plug and that's what I did. But just for reference/curiosity that fitting that is OEM is actually a 26mm-2.0 compression union. The thing is that 26mm thread form doesn't even exist in the Machinery Handbook - jumps straight from 25 to 27mm. Maybe Toyota did this because it's emissions related and they wanted to make it tamper resistant.
It's an M26 thread.
The 2 plugs are available from tlcperformance.com.
Get the plugs here. There are some threads floating around with Dorman part numbers for these plugs but I ain't gonna say who posted those numbers cuz it's better to get stuff from this @FJ40Jim guy :D
No, sorry, the brass threaded plug is for the 2F EGR connection.
The 3F EGR exhaust manifold plug is a large steel allen bolt. It also fits 75-76 2F exhaust manifold EGR connection, FWIW
The 3F plug still hasn't made it onto the webstore. Price is $10 for allen plug & crushwasher. $2 for cup plug into intake mani. $8 for PriorityMail. $20 altogether.
Mods: delete if this is too commercial.
Thanks!
Thanks!
That's a good deal on parts you know will work instead driving all over town to track down parts.
Thanks!
I need to hold off on ordering anything until I find out for sure that my spare 3FE exhaust manifolds can be installed on an early 2F cylinder head - casting number 61030.
Thanks!
Jim, do you have the 3FE exhaust manifold EGR threaded plug available? Need one, maybe two.
