- Thread starter
- #21
@Godwin
Was this done for the replacement to part number 85915-60010? My mechanic says I need to replace 2 relays to get "Nancy" running well again. The 2 are in the front passenger wheel well. I have found part 1 and part 2 on CruiserParts.net but everything I've bought from them in the past has been utter crap. Also, part 1 [85915-60010] is $100 used and part 2 [85910-14020] is $50 used. I am not sure that spending $150 on some used parts from that website is going to be the right move. Let me know what you think, please.
Also, I have a 5 pack of some Bosch-type relays I bought off of Amazon about a month ago. Their description is as follows: "40/30 AMP 12V DC Waterproof Relay & Harness". Could one of these be used for part 1? Your original post indicates yes. What do I do about part 2? Thanks for any and all help with this matter.
"Nancy" is a daily driver and I'd prefer she stopped stalling on me. She has the following new parts: radiator, battery, battery cables and grounds, spark plugs, spark plug cables, distributor cap, ignition rotor, fuel filter, throttle position sensor, air filter, oil filter, starter, oil pressure sender gauge and alternator.
I would not spend the $150 on used electrical parts from Cruiserparts.
When I replaced the EFI main relay 85915-60010 I used a standard Bosch type relay. It's simple enough to wire in that your mechanic should not have any problem doing so. I think the same approach can be used for the Circuit Opening relay 85910-14020. With both of these being discontinued an alternative is needed so do it now instead of plugging in used parts that have an unknown longevity.
I use Waytek Wire for electrical items; here's a relay example that would work TE Connectivity V23234-A1001-X036 High Current Mini Relay | Waytek
