For Sale FJ60
Scottsdale AZ
For sale is an on frame restoration FJ60
184,500 miles on original 2F 4.2 straight-six motor
A plethora of mechanical work has been addressed to include countless hours of engine compartment reorganization and beautification.
6" spring over lift, extended brake lines, extended differential breather lines and extended drive shafts
Man-A-Free Offroad: high-steer kit, ceramic headers, fluid heat raiser kit, Y pipe, high flow catalytic converter, FlowMaster muffler, 2.5" exhaust pipe, additional sway-bar in the rear with sway-bar disconnects on the front and rear axles.
4 Bilstein shocks and a coil over steering stability shock
New 35 by 12.50 BF Goodrich all terrain tires on 15 by 8 aluminum rims and one new (same dimension) spare tire and rim
New Battery, new windshield washer fluid reservoir, new radiator fluid reservoir, new wiper blades in the front and rear, new hoses, new fuel lines with fuel pressure gage.
Converted/modified the alternator system to a 1992 Land Cruiser alternator with 90 amps as opposed to 55 amps from the stock alternator, with beefed up wiring harnesses.
New restored to original paint job, protective undercoating under the vehicle, wheel wells and bumpers
Hand-made bumpers in the front, rear and rock sliders with rear corner panel bash guards
Towing hitch in the rear
Both differentials are rebuilt with 4.88 gears, mechanical lockers and Long-field front axle shafts.
Converted from carburetor to Holly Projection 1D fuel injection (manual adjust) system with cold air intake (K&N cone filter)
Custom side view mirrors with turn signal accent marker-lights from Japan
Electronic ascend descend radio antenna
New front windshield and all new turn signal accents after paint job
Tinted windows
Prestige alarm
Four speaker JBL stereo system
All original owner's manuals', repair manuals' and tools'
This RIG fits in any standard garage with about a couple inches of clearance
I'm the third owner, own it since 2002, it's an Arizona vehicle with no rust.
AC system works but it has a freon leak that needs repair.
Asking price is reasonable, especially considering how excellent mine is. 25,000
Call (Five 2 Zero) 3 Zero 1 - Zero 6 Two 5
