FJ60 PS fittings
[hijack]TJ, 60 PS and pump?[/hijack]
Yes sir - 60 series pump and box on the 40.
Even with the 16 x 1.5 mm knowledge, I was SOL at the hose place.
So I will head to Summit and order up adapters, then make new hose.
I am a little confused by Mace's post; I thought JIC was a metric-type standard and AN was a standard size?
JIC is steel AN = Aluminum..
They are the exact same thread pitch/style.
SAE is different.
-6an/jic is the same
Order the adapters from lee and order the hose from a local place. If your hose shop cannot make a -6jic hydraulic hose they are seriously worthless...
Or get the resuseable ends from summit
pump side is 5/8 x 18 inverted flare to -6jic
Hose -6 jic to your length
hi press box side is 16mm x 1.5 inverted flare to -6 jic.
Return line should be easy with the stock lines..
I thought the high pressure hose had the same fittings at both ends - pump & box? :confused:
High Pressure Port - 16 x 1.5 MM Inverted Flare to #6 JIC Male adapter, Toyota - 'PSC Motorsports' #PSC-SF06 or 'Summit Racing' #EAR-9919DFJERL
Low Pressure Port - 17 x 1.5 MM Inverted Flare to #6 JIC Male adapter, Toyota - 'PSC Motorsports' #PSC-SF07
As I understand it the smaller port is the press side.
Or
LEE MFG. CO in Sun Valley CA
818-768-0371
has
16mm x 1.5 inverted flare to #6jic for the pressure side and
17mm x 1.5 inverted flare to #6jic for the return side for
$8 each
Mace,
I'm guessing I would need one each of the above and one other fitting to use on my V-8 swap. I'll be running a 5.7 Vortec with GM p/s pump, and will retain the stock LC steering gear. So would it be correct to order one each of the above and then what every it take to adapt to the pressure side of the GM pump?
Box side
16mm x 1.5 inverted flare to #6jic for the return side and
17mm x 1.5 inverted flare to #6jic for the press side for
pump side
5/8 x 18 , -6an (jic) (press side)
Any hose place can make you the -6 ended hoses..
The return side is very low pressure. a slip fitting will not be a problem...
Low Pressure Port - 16 x 1.5 MM Inverted Flare to #6 JIC Male adapter, Toyota - 'PSC Motorsports' #PSC-SF06 or 'Summit Racing' #EAR-9919DFJERL
High Pressure Port - 17 x 1.5 MM Inverted Flare to #6 JIC Male adapter, Toyota - 'PSC Motorsports' #PSC-SF07
Or
818-768-0371
has
$8 each
Box side
pump side
Alright, just seeking clarification here Mace - in some places you are saying the pressure side is 17 mm, and other places you are saying the pressure side is 16 mm.
Which do you believe it to be?
Thanks!
press is 17mm
I was confused and did not fix everything...
Actually I took my own advice and plumbed it the wrong way the first time ;)
Or
818-768-0371
has
$8 each
For some reason the P/N's listed don't show up on PSC's website? Did you have to call and order?
I bought from Lee...
Been posted about 5 times in this thread
818-768-0371
O-k, I am not sure about what box you are running, but I just installed my custom hose using adapters and it was 16mmx1.5 to 6 JIC for the pressure side...
Don't be shy about making your own hoses, the hoses are very easy to assemble and you can make them in the comfort of your own garage and have the ends oriented how you need them, and at the right length.
