FJ60 new clutch - feeling odd pops through pedal
kenavt
Seattle, WA
Website
www.instagram.com
Hey folks, having issues with my new clutch on my FJ60 and hoping to get some debugging help.
Namely, I feel a weird sensation through the clutch pedal during some actions. I feel a sort of pop (or a weak kickback) when doing one of: pushing the clutch down, coming off the clutch, or even sometimes when i have the clutch pushed down and just move the shifter out of neutral into a new gear. I think when the truck has warmed up it goes from some actions to most. It's really disconcerting. I think this might have happened a couple of times starting from a stop, and it has the result of feeling like the clutch has just released and I've slammed into gear. Worst it makes me feel reluctant to ride my clutch in the friction zone at all once I'm warmed up.
My leading theories after taking my inspection cover off: that the front surface of the throwout bearing is still dirty and might be catching oddly on the pressure plate (my rear main seal is definitely leaking, possibly my transmission too, the bell housing is all dirty). Maybe I can disconnect the clutch fork and wipe off the front of the throwout bearing. That, or maybe I have air in my clutch fluid lines and need to bleed them some more.
Secondary issue I have that might be related: I had to adjust my slave cylinder pushrod to be all the way out, and then adjust the clutch pedal beyond the FSM's pedal height adjustment measurement (instead of 7.13" it's over 8"), and the engagement point is still pretty low. I did get my flywheel re-machined and it doesn't look too off.
For background: I replaced my clutch two months ago with the Aisin CKT-032 kit, also got new OEM slave (adjustable pushrod) and master cylinders and hose that runs between the two. Had an issue for the first 300-400 miles/two months where the throwout bearing was squealing when in the friction zone (link), that's mostly gone away now.
Could also be that your clutch disk is not sliding smoothly on its splines. Either due to dirt or a metal burr
hard to tell but it sure looks like the throw out bearing is wearing into the fingers of the diagphram of the preasure plate
I went back and had a look at the previous post on your clutch issues.
Your pressure plate is NOT bolted down fully against the flywheel!
Watch the second video that you posted a while back, and right at the very beginning look at the p- plate bolts and you'll see there is a gap between the pressure plate and the flywheel!
The entire pressure plate is moving towards the flywheel when you push the pedal down, and away from the flywheel when you release the pedal!
The pressure plate needs to be bolted up and torqued so that it sits hard up against the
flywheel face.
Did you fit new bolts to the p- plate that are too long and are bottoming out, or are the bolts not fully
tightened down?
flywheel face.
tightened down?
Oh my god... looking back at the videos, you're exactly right. ,
When I bolted the pressure plate in, I torqued it to the FSM stated 14 ft-lb, and that gap existed... I thought it was odd there was that gap but had never put a clutch together before, just kinda thought that's how it worked because I torqued to spec. I did think that torque spec was pretty low and they should be torqued higher, but... just trusted the FSM.
I did fit new hardware, I'll double-check that I haven't bottomed out. I am not sure if I loctite'd them, so I'll also do that in case they started backing out (I know I did some flywheel bolts).
OK, I'm 95% sure I'm bottoming out. Pulled out one of the new bolts (loctite'd) and its 25mm long, I bought new from O'Reilly's generic hardware.
However, the correct Toyota PN is 90119-08134 (edited) per Partsouq which looks like an 18mm or 20mm bolt from various pictures floating around... going to call up the local dealership first thing in the AM and get those bolts in. And I would say 5mm is roughly the distance that it looks like I'm off.
I remember now getting that length 25mm from a PDF I found floating around on MUD inventorying all bolts for FJ60s... allfj60-bolts-97-2003.pdf. That's the last time I trust that PDF!
Are those generic bolts even grade 8.8 ?
I would never use anything for that part but an OE bolt, if available. Plus, those bolts need a lock washer - That's why the OE is a sems.
Luckily, you won't need to remove the trans to replace those bolts.
This is what I bought - looks like its grade 10.9. Definitely no lock washer. https://www.oreillyauto.com/detail/...read-bolt/dor0/981425d?q=m8-1.25mm+25mm&pos=5
I've been hit and miss on OE bolts for things I thought were non-critical (e.g. recently replaced driveshaft bolts with OE but not these). The stealerships around here charge >2x over list price even when you challenge them on list price, and I tend to be impatient since its almost always next-day... but that's going to change from now on.
Alright, new OE bolts in just fine, did a few passes torquing it up, then re-adjusted the slave cylinder pushrod and pedal height, drove it around the block, and... the clutch feels great. Until I took it for a spin around the block, I didn't realize how nervous I was and how awkward and odd the clutch felt - not only the popping behavior I talked about previously, but just how gingerly I was using it and how naturally smooth it feels now. And also the pressure plate fingers look like they're more tucked in to my eye.
I will have to re-visit pedal height since I didn't have a tape measure on me, just lowered it (from where it was previously, which was too high). I thought the engagement point was initially too high but it got better when I lowered my pedal height to closer to FSM spec.
Does my slave cylinder pushrod positioning look right (as shown in the spacing between the throwout bearing and pressure plate)? I think I have it ok. I've never seen a FSM that had guidance on this, and haven't seen much on MUD either.
On the later model FJ60s (86, 87) the clutch slave cylinder automatically adjusts the pedal height. On those vehicles the clutch begins to move when the pedal is pushed down just a little from relaxed. There isn’t much play at all between released clutch and working clutch. You might be able to use that behavior as a reference.
The release fork fingers that contact the hub ears experience a lot of friction and high loads. There should be a glob of grease between the two release fork fingers and the hub ears. Leave a bit of grease clinging to the outside - it weeps in to the spots that need it
I forgot to follow up... I set the pedal height properly per FSM, then played with the pushrod cylinder a bit intuitively (didn't measure there), added more grease (thanks @OSS), and everything feels great. Have put 500 miles on the clutch since then. Feels just as it should! Thank you @GM60 and all ☺️
how long were the OEM pressure plate bolts? 90119-08134?
They are 90119-08134... I double-checked my paper receipt and that's what I ordered and installed. As for the length... I want to say it was in the 20mm or 18mm range but not certain. Since the generic too-long ones were 25mm. Partsouq has a picture of the part if that's helpful at all.
I was trying to read the part number info from Beno's great guide FAQ - Understanding Toyota Hardware Part Numbers And Other Part Numbering Thoughts - https://forum.ih8mud.com/threads/understanding-toyota-hardware-part-numbers-and-other-part-numbering-thoughts.1177159/, but wasn't able to come up with a length that made sense (34mm?)
Yes, helpful. didn't see that pic. I can count the threads and extrapolate. :)
