fj60 exhaust doughnut gasket?
Norcal, not on fire but it was darn close.
Im in a rural town so I need to get any info the Napa guy can use.
Last time we matched it up with some part.
I failed to find an online manual and you cant trust the parts guy.
Both napa and orilies sent me home with the wrong gasket.
O boy o boy doughnuts.
OEM 90917-06056
Walker 31350
Fel-Pro 60915
HTH
Both the OEM and Walker part numbers are different between the 60 and the 62 (NAPA uses the Walker number). I have an 85 also and have no idea if the later gasket will work. I have a spare that measures 3.125" OD, 2.625" ID and 0.235" thick. If the one you got is close to that, it might be ok to run, at least until you can order the right gasket.
Fel-Pro 60915
VICTOR F20257
AutoZone 60915
AutoZone F20257
WD EXPRESS 224 51040 368
I used the felpro 60915.
So basically the late model FJ60 and the FJ62 exhaust donut are the same? @beno
not that I'm aware of, the 2F has 1 large pipe, the 3FE has 2 smaller pipes
Is the exhaust pipe flange gasket and exhaust downpipe gasket the same thing?
The exhaust pipe to manifold is going to be larger than the flange gaskets at the cat. Make sure you get the right one.
@lt1823 , like Tupperware I tell you.
Haha Roger that. Appreciate the help. Just got the Felpro 60915 Exhaust pipe flange gasket from Autozone for like $5 and the hardware/studs/nuts from SOR. Do you recommend replacing the hardware with bolts for easier removal next time?
