FJ60 brake booster
Hojack
♠️Project Snowball❄️
Cascade Foothills above Eagle Creek, Oregon 🇺🇸
Hey gang
I’m needing some help on my brakes. I’ve installed new rear pads and calipers on the 80s rear axle swap. I’ve bought and installed a new master cylinder from @cruiseroutfit and Wilwood proportioning valve for the rear disc brakes. Bench bled the master. Installed the master and bled the air from brake system. Bled brakes until all air was out and fluid was running clear. Bled the fronts the same way. I have a new vacuum pump on my 4BT Cummins. Took the 60 for a test drive. The brakes work but feel no assist. Remove the vacuum hose and there is suction. I need to get a vacuum gauge to get a number but it’s enough to suck and hold my finger to the hose. The hose is 3/8 vacuum hose so I know it’s not collapsing as a fuel line would. My brake booster is stock and so I’m wondering if the booster is the problem or my new wabco vacuum pump. Help would be great.
Boosters definitely fail. There's very good brake booster troubleshooting tips in the Body FSM.
Does it say anywhere how much vacuum you need to have the brake booster work?
I don’t believe it does say. To me it seemed vague when I read it but I could be way off. @mwebfj60 seemed to have some good insight on a bad brake booster back when I wasn’t sure if I was having an issue w/ mine.
I’m wondering if the 2F had more vacuum then my 4BT vacuum pump.
Have you installed an air reservoir? The vacuum pump on my 1HZ reads 30 inches.
Normal 2F gasser that's wheezing at altitude will suck maybe 15 inHg of vacuum and still have plenty of vacuum assist on the booster. Brakes work well.
At sea level they can get 20 inHg, but braking isn't noticeably improved.
Dual Diaphragm Disc Brake Booster for Land Cruiser FJ40 FJ55 FJ60
Anybody replaced their brake booster with this one from City Racer?
What’s this about an air reservoir?
Basically the same as an accumulator in a hydraulic system, adding capacity during high demand conditions, i.e. stop and go driving. If your vacuum pump has sufficient capacity, you don't need one. Most Toyota diesels have them. Don't know about Cummins.
Do you have a link?
If you look just to the right of the brake master cylinder, you can see a silver tank.
On my 4BD2 Isuzu diesel swap into our 60, I don't run a vacuum canister or accumulator tank and the brakes have much more power assist than they did with the 2f. The vacuum pump is on the back of the alternator and the booster is stock 2f.
The vacuum pump creates a more consistent and stronger vacuum than the 2f intake ever did. I don't run a vacuum gauge, so unsure of actual vacuum.
I have never had any issues with stop and go traffic, and have stopped the engine and made 3+ brake applications that were still power assist.
Maybe a bad booster?
Reviving the thread a bit. My FJ62 had significant trouble stopping last week with an 1100 lb. trailer of scrap steel. I have never seen it this bad, but I jammed the pedal as hard as I could, and it rolled to stop rather casually. No way could I have locked a wheel. Booster seems to have enough boost and does not leak down overnight, so I will check the flex lines at the wheels. I run OEM pads and rotors and the rear drums have new shoes. I have 31x10.5 tires - all else is stock. Normal braking without a trailer is fine. Any other ideas?
One clarifications - are FJ62 and FJ60 boosters the exact same unit?
Thanks - Steve
Thanks - Steve
Did you have functioning trailer brakes?
No - it is a pickup bed trailer. I tow this trailer regularly behind other vehicles, and something that light doesn't really need its own brakes (driven sensibly).
I will re-check the booster's ability to hold vacuum, and line to it - thanks.
