I won't work up front without looking goofy. The box is longer than the frame rail. You can physically get the bolts on the frame, but the ass end hangs off into space and the bumper won't fit back on. The relay rod will go back to the axle at about a 30 degree angle, too.
I know this because the PO used a cast adapter to put the p/s box in front of the crossmember.
I relocated it behind the crossmember. I tried an astro box, but the pitman arm stuck forward too far. I didn't like the idea of leading with my pitman and I didn't like the angle back to the steering arm.
I ended up with a normal sag box located in front of the crossmember. The relay rod now goes forward to the steering arm as the end of the pitman is above the axle. Not an issue with a SOA, but kinda goofy. No interference with the tie rod as I am using a 4x4 labs set up with a tie rod behind the axle.
The steering shaft is tight, but not any tighter than most other options.
