fj55 sag PS?!
Josie'sLandCruiser said:
Why not use the PS gearbox from a K5 Blazer? It mounts outside the frame rail like the Scout PS 'boxes but is much more available.
Seattle
you mean like retain all the stock steering parts and just use a "power" box?
if im gonna go to all that work, i want to eliminate all the weak links possible, on the stock steering set-up, i see on extra rod, 2 extra ball joints and an idler arm that can be tossed......
i hope this is what you meant...
i think it was on here, someone used a mini box and mounted it sideways and used all the steering parts.... seemed kinda pointless to me, anyone have any more info on that?? i mean the guy did a nice job, just seems like it's all for nothing??:confused:
The one thing about the scout box is it has a 4.25 ratio lock to lock you'll have a hard time finding another box other than a regular saginaw with that much mechanical advantage . Piggies are a little longer than 40's so road manners will differ slightly but if it is going to be wheeled the higher ratio will prove itself more worthy, aside from plans to run ram assist from the beginning.
