fj55 leaf spring swap
Tucson
Hello.
is it possible to swap leaf springs from a 60 series (62 to be exact) onto a fj55 chassis? Or will it be too short? I currently am in the process of buying a fj55 and the leaf springs are flatter than a pancake,
Thank you,
Ih8muff.
If you are looking for a straight across swap, the answer is no. If you are up for little fab work, anything is possible. Did you see if OME has 55 springs available? I love the FJ60 OMEs I have on my 40.
Cruiser Outfitters does have OME springs for a 55. Didn't check prices, but you can get 'em.
Those are not bolt right up... those are for 75 series and require relocating hangers. No off the shelf bolt right ins... you can add a leafs, or spring over with your existing, or get custom springs made or you’re going to be cutting and welding. If you are going to cut hangers, keep in mind 55 spring pins are centered; all others have offsets. Some fj40 tears up front, and some Chevy 63”era in back should make a nicer ride...
Would it be best to simply get the current leaf springs re-arched? I am very excited about this prospect and hope to share the build thread immediately after formal acquisition.
That is the easiest way, but consider having the blacksmith add a leaf, as rearching does not fix worn spring rates
Very nice, thank you for your input lambcrusher! I think the leafs will get done after the motor is up n running, but I need to have plan of action in place as this is a noticeable task on the to-do list.
one More thing, don’t add extra arch, as it causes the shackle angle to go the wrong way...
I put the OME's from cruiser outfitters on mine. Fronts are a direct swap. On the backs, you have to more the rear hangers back about 5". One of the best upgrades I've done.
I thought these bolted right in? Cruiser Outfitters
