Build FJ45SWB recovered from a barn
Canaima is finally getting a refresh on suspension. Time to get rid of those 60 year old springs. - 255/85R16 are also on the way. Thanks @cruiseroutfit for helping me to figure out what I needed to make this possible. I will try I to get to it this weekend
Nice! Are those the mediums or heavy springs?
why did you end up not going with the Dobinsons?
@cruisermatt i wanted to try something different but They gave me. 4 months. ETA - by the time I get it from them it will be winter again 😂. I el decided to go with OME and bilsteins. Anything will Be better than what she has now
Medium. Rear pack looks massive. I might have to take a leaf or 2 out. We will see
You definitely will want to trim up the CS003R's for lighter 45's.
Fwiw we stock Bilstein and Dobinson shocks too. Have for many years :cool:
So I decided to get a little adventurous and took the top of. Can you guess how many bolts I broke ?
Usually its in the “lots” category!
Well, mine felt under the all category. 😂 thank fully my buddy Jim and his welding / metal work super power came to save the day
This was a true miracle. We were able to get them all out. Correction he did. My Original plan was to drill those out and add rivnuts. But since we save them all I just tap them. We also got all the dents out
This is what victory looks like after long day of work. I waited almost a year and drove 400 miles so he can help me get this done. I knew it will be worth the wait. Nothing that a good talk and tacos can’t fix. We also got some dents out and now I will focus on cleaning the rust spots clean before sealing the top and putting it back on the truck for another 60 years.
Hey @KT40 sorry I missed your message. This are mediums. We might be putting them on this weekend or next. The rear pack is massive so we might take one or two leafs out. I will post more info once installed
your gonna bounce off the bumpstops.. you sure you don't wanna toss those springs on real quick?
I got new OME suspension that will try to install before the weekend. I just some extra parts I needed. Honestly I could wait to see her with the new tires. It should look better once everything is done.
What wheels and tires are you using? I'm looking for something similar for my FJ40.
thanks,
Nick
Hey Nick, those are tacomas steelies. You can usually find them pretty cheap. You will need a 1.25 or 1.5 inch socket since those have a 4.5 backspacing. Tires are Yokohamas 255/85R16. Same as a 33 inch tire. This will be my first time with the Yokohamas, so I cannot give you any feedback there. But I heard a lot of good things o those.
Scrolled through a lot of this thread, was the VIN tag ever posted on this? Curious as to what the model is stamped and if the frame # starts with 2-FJ45-xxxx
Bump on previous post ^
Also curious what the VIN tag says the original motor number is. Thanks for any info.
