FJ45lwb tank options...
Very productive weekend with the Cruisers, I even took the 45lwb to town and almost died from the gas fumes in the cab I guess removable tops have more that one advantage.
After returning from my adventure I went ahead and removed the seats & fuel tank from the 45 and the tank has some rust and appears to be leaking at the seams (seam tape and fiberglass found) The good news is the floor pans are in great shape and no rot was found.
What are my options for a tank for the 45??? I'de rather keep the setup I have since the gauges and sending unit work as is but I'm not sure boiling and relining the tank are viable options due to the seam rust.
Opinions???
pics to come...
I definitely would go for boiling and relining. You'll do fine even with the seams, I'll wager. Consider the POR15 folk's kit.
thanks guys, still looking locally for a shop that will boil it out and seal it for me but it's not looking good. My alternative would be to aircraft strip the exterior and Rhino line it and then coat the inside.
Pics!
#2
#3
#4
Dredging this up in a search :D
Did the 77 FJ45LBP share the same tank as the FJ40 from 77? My 45 has one of those 40 gallon jobs mounted in the bed that I'd like to replace with moving it back to a stock location. If they didn't share the same tank, what other alternatives are there?
here's a link to what I have now
Jerry [DeepSouthCruisers] ran a thread on this over on PBB last year. Fairly extensive. He eventually got the tank fixed, then sold his junk to Jason [heavytlc]
I finally got my tank boiled out and resoldered late last year and it is like brand new again. :bounce:
That said, I also run an FJ40 aux tank that I modified to mount in place of the factory tire carrier under the bed of the LWB. You can see it in the last pic on this thread:
http://www.pirate4x4.com/forum/showthread.php?p=3910459#post3910459
PS. 45 owners have their own forum on this board now. ;)
That box is exactly what I was looking for a few months ago. I ended up just buying a Jaz 32 gallon aluminum fuel cell that mounts perfectly to the lip on the front of the bed.
I've also got the stock tank that I'm going to have cleaned and reinstall. Should be nice having almost a 50 gallon fuel capacity :)
I'd say not. For one thing, the cab shape is different, wider, and you still have your bench seat, which the FJ40 did not. The filler also is in a different spot.
Owyhee Jackass said:
Until you have to pay for it...50*2.3=$115.00!
Dude, you are so spot on.
Got any thoughts then on an alternative? I need something that is not going into the bed and I'd prefer to use the stock filler location. Maybe I'm in fantasy island?
Well, it LOOKS to me like your 77 original tank was in the same place my 9/64, which is underneath the passenger bench seat, inside the cab, right Mike? I know that at some point in the later 70s they moved the tank out of the cab and under the floorboard in the FJ40s, so I assume they did it in the FJ45 as well. But I don't know for sure or what year.
I think your choices would be to:
1) Find a stocker in Canada or the US and probably fix it because most of them leak or they are in use. (good luck)
2) Use polyethylene aftermarket tank built for an FJ40/45. See here: (http://store.yahoo.com/coolfj40/gastanfj19th.html)
3) Build or have one built out of steel that basically mimics the original tank. (Test your skills)
Being that I likely won't find in canuckville, and refuse to give CCOT any of my money, I guess I'll try option 3 - set truck on fire :D LOL, will go that route and look for a custom install I guess. Can't be too bad.
If you can find a shop that will graft the filler neck from your original 45 tank onto a brand new early model FJ40 tank, that is another option.
Of course, there is still the issue of the replacement tank having a standing seam front and rear that the original tank did not. :frown:
