I have searched and read the posts on vapor lock. I MAY have solved the problem by patially insulating my fuel pump and the fuel feed line to and from it. I am unable to get my mechanical fuel pump away from the hot exaust pipes. There is a half inch "sample pipe" coming off the header that runs within an eighth of an inch of the pump inlet. (Need it for smog in CA?) My questions are:
Should I remove the sample tube? (easily done, what about smog?)
Try to better insulate the sample pipe?
Install an electric pump and abandon the mechanical? The e pump needs to be lower than the tanks. I run dual tanks, one under the frame in front of the axle. Feed problem? Is the e pump water proof?
Thanks all,
Jim
Thanks all,
Jim
