Hello to all. I have searched here and online, and have only found corrections that I have already done. This is a 1990 Chevy 5.7 TBI with a 700r4 trans. I have a 8274 Warn winch that does block some of the opening. I have put in an aluminum radiator. It sits just between the headlight buckets (wide), almost hitting the plugs. it is as tall as stock. It has a fan clutch (the short one) and a Duramax diesel 11 blade fan. It also has a custom made fan shroud that the fan is half way out and is spaced perfectly on the sides. It also is spaced away from the radiator, per spec. The motor is well away from the firewall and the thermostat was 195 and then I switched it to 180 with better results. Timing is stock. The only upgrades are headers and a 110amp alternator. It runs like a champ around town, but going up hills it just keeps heating up. I have been stopping around 230 degrees and then stopping to let it cool down. This was the same problem with the small radiator and electric fan. Only difference is, that it wasn't great around town before. I have only been able to test this during 95-100 degree days in California, but I want it to work during hot days also. I was thinking of cut the inner fenders by the headers to see if this is causing the heat soak. Hoping it would release the heat causing the buildup. I will then screen them in once this may fix the problem. I was thinking of taking the hood off to test the theory first. What do you think. Any theories or opinions would be appreciated.
Lucas
Lucas
