FJ40 Tub Corner Radius?
Flagstaff, AZ
Website
www.youtube.com
So I've scoured the entire first page of google searching for the dimension for the radius of the FJ40 tub rear corners and can't find a mention anywhere of the actual size. Does anyone have it? I am trying to do a mock up in CAD for a future project and currently do not own an FJ.
I don't know it, but I could measure it for you. Where do you want the measurements?
well its probably best to just measure the distance around the curve and since we know its a 90 degree bend we can find the radius that way. could you just hold up a string or something and aproximate as close as you can where the bend starts and ends, then measure the length of that string?
This will be some good info!
Are you referring to the radius at the lower corner of a 79 - 84 ambulance door? The lid I’m holding up in the picture is 2 inches in diameter.
Just hold up a framing square to it then make the best call where the curve stops and straight begins. That'll be the radius.
Oh wait. You don't have one to measure. I'll give it a shot.
OKl Not real easy to tell exactly where the curve stops and straight begins especially on my old rusty body but my best eyeball has it at 5-7/8" which is real close to 150 mm.
There has to be a number of FJ40s in Flagstaff. I drive thru there occasionally and remember seeing a few. Couple of them were parked. I have a few FJ40s in the northern half of the state. These are all still original with two still with original paint. I have a framing square could measure the radius if you want. Figure just a something skinny could get real close to where the straight ends and radius starts.
Yea when I lived there I did occasionally see some. I guess I should update my location but seeing as I am only temporarily living in the Portland OR area, not sure how long I will be here. I liked living there but there are not so many jobs in the mechanical engineering field there. I just graduated so now I'm looking around for a job and in my plentiful spare time I am planning an FJ40 build some time in my future
There goes your plentiful spare time.............
An old 'cruiser buddy of mine used to wrap his steel piece around an acetylene cylinder to create the rear quarter bend radius. Might be worth a try with a scrap of steel.
Looks like it was answered, but I just checked mine and also got 5-7/8” inside radius. I used a motorcycle pulley and stuck it on the inside radius and it was perfect. (Hard to tell from pic).
does anyone make the channel aftermarket, mine are severely rusted, but the outer layer is good, i'd love to grind them off and replace them
