FJ40 rewire
I need to rewire my '73 FJ40. Problem is, none of the wiring diagrams found here match with mine. Does anyone have a simple universal diagram that I could rewire my cruiser with? I hate seeing her set there not moving.
Pull the existing wiring out and re-rap it. Replace the fittings and burnt wire as needed. You will find plenty of new fittings from members, on Mud.
$225 with free shipping.
You can also find good used fittings here one MUD. I've been harvesting a Toyota Pickup harness and have also picked up used fittings from others. Once you find out how to remove the pins from the various types of connectors used by Toyota, you can replace those as well. I recently bought a supply of male and female spade and bullet connectors from coolerman.
A lot of good information here, including a good photo of an entire '72/'73 harness:
You say it doesn't match the schematics, has it already been rewired?
What’s the manufacturing date? Could be a ‘72 or ‘74, depending on the month.
What doesn’t match the available schematics? Everything? A few specific items?
The link provided by @4Cruisers, above, offers some great insights.
The schematics I've seen, show 2 wires going to ignition coil, I have 3. I'm not sure which is positive or negative. I also have an aftermarket starter, unsure which of the smaller lugs I'm supposed to wire to what.
The harness on my jan 73 FJ40 was wired for the later model rear combination lamps, i.e., red, amber and clear backup. My truck has the older round rear combination lamps, with brake/signal and parking lights, with the separate backup light on the left rear quarter panel. I believe that Toyota upgraded a number of items in anticipation of changes.
Note that my cross member behind the transfer case is the four speed version with the big offset in it, even though four speeds weren't introduced for several months later.
I have yet to find a wiring diagram that reflects my wiring harness.
I got connectors from Coolerman, and refurbished the wiring harnesses subject to weather, like under the hood and the harness to the rear. I also added separate ground wires for each of the lights, thereby avoiding scraping off fresh paint to get a ground path for each and every light.
So, I've figured my best bet is to go with HEI and do away with the extra wires. Anyone know of a good write up or video on using a GM HEI dizzy?
Sorry... no, not GM HEI. I could help with DUI.
But, here are a lot of links to HEI discussions and DUI discussions... because they are similar.
But, I’d like to stress that when DUI was first marketed for FJ40s, Davis Unified Ignition didn’t recognize that Toyota dissy was geared a bit differently, from GM.
It wasn’t until a few FJ40 engines were trashed before DUI corrected their Toyota DUI gearing.
The moral... be sure you don’t fall into this gearing problem... if it applies to HEI installations.
