Here is the first startup with the exhaust.
Sounds great!
OK cool, if you have experience with the fittings then all should be good. But ja, losing oil pressure at 6k rpm would suck. A lot.Good point, I may change that now that you point that out. It should be good for the 60psi but then again losing all my oil is a bad day. Those are the same fittings on my air compressor at 120psi so in theory they should hold, if they don't loosen from normal vibration.
