Hesitation or failing under load in early stages might notice it first going up a grade engine will appear to stumble as the pump isn’t providing enough fuel to the system.
When the diaphragm gets worse it will make starting hard as the system doesn’t keep fuel above and needs to prime or struggles to prime even.
If you are refreshing everything it would give you a known starting point. Depending on how you use the vehicle it could save you from dealing with it on a trip or where parts are tougher to get. This is coming from someone who changed a fuel pump in a parking lot on a road trip. So my view might be on the more conservative side.
We do have a Holiday Sale running now through 12/2. 10% off your order and if you are spending over $125 you get a free hat.
Cheers
Dave
