Came across this vid
I am looking to learn from someone on this as its my first frame rivet experience. Have you done this before? do you have any suggestions on how to do the boxed in/difficult to get to rivets? or what bucking tool was most useful for the boxed sections? thank yoU!Oh my God. Damn a Toyota rivet. They are the hardest things known to man. Someone on the first page saying they were going to remove all the rivets on his Cruiser....
Did you have to drill out all of the holes to accept the 7/16" bolts? The major diameter of an M!0 bolt is 0.3937" which is too big for the holes the rivets came out of. 7/16" is 0.4375", which is even bigger.My 40 is defiantly not a factory restoration. In areas where I had to remove rivets for repairs and modifications and would be unseen I would use 7/16 grade 8 bolts. Where the rivets would be seen I used 7/16 button head bolts, welded the allen hole closed and filed off any extra weld before installing them. They are a bit bigger than the original rivet head, but to the casual observer it will pass.
I got mine here 3/8" ROUND HEAD RIVET SET FOR RIVETING HAMMER | 3/8" ROUND HEAD RIVET SET FOR RIVETING HAMMER - https://www.rivetsonline.com/38-round-head-rivet-set-for-riveting-hammer/to-10-43012Does anyone know where you can buy the rivet setting dies shown in picture in post #21?
answering my second question: 8mm in a 9mm hole is not advised.Hi, i've got a couple of questions for those who installed new rivets.
If the shaft is 3/8inch (9.5mm) diameter, is it correct that the new rivet head diameter measures 5/8inch (16mm), compared to the original 9/16inch (14mm) heads?
Second question:
I think someone here bought 5/16inch (8mm) diameter shaft rivets, did that work out in the frame's 0.3543inch (9mm) holes? Seeing that the 5/16in have 14mm heads by default, it got me thinking that maybe Toyota used these originally and the hot riveting process fills the hole in the width when hammered?
