Fj40 Exaust location
can count on you for the :rolleyes: to make a guy feel a bit dumb... but remember, I am asking as I have not tangeled with exhaust and don't know. ;)
"often worked on" was just implying maybe needing to work in the area and having to work around or with an exhaust pipe running across the area (do not know if peoples exhaust would run across the oil pan area or t-case or clutch area or what). Does not mean I had exact idea in mind, just trying to visualize why and how and the possible complications IF work needed to be done so why run it across if not necessary.
"route it down the passenger side of the truck" - heck, down the ouside of the frame rail like mine is? or I dont know, maybe a good muffler guy can run it up over the t-case and back down? I have no idea as I am not savvy in that area.
As for the power loss.. just going on what knowledge I have read and been told about exhaust airflow constriction and I would think if Woody felt a "noticable torque loss" with an exhaust confiuration change... maybe you could/would sense and feel it with this cross over and multiple bend configuration.... but I was more hinting at if it was tested on a machine versus by actual feel of the user.
You sure have the self-deprecating thing down, don’t you?
You can read anything into what I post out here that makes you feel however you want it to.
I have implied anything about you being stupid.
Go back and read Brian's post, and you will see that he increased the diameter of the system to 3" and said that it had a negative effect on low RPM performance.
Read what I post, and stop reading into it.
Have a great day!
-Steve
woody said:
switched to block huggers, a custom Y-pipe, and a single 2.5" exhaust...loved it...
switched "yet again" with the same block huggers, a slightly larger y-pipe, and a 3" exhaust...noticable torque loss....
1973Guppie said:
why do you need dual exhaust? just more pipe to find room for....
I run block hugger headers, into a y pipe and straight back, flowmaster is tucked up and then exits out the pass side rear. I have a rear conferr type tank too. My advice, find a good exhaust shop in your area. A good exhaust guy can do it, the guy I went to did a sweet job, it cost me about $500 though....
Noah
Guppie, id like to see a pic of your exaust setup if you have any. Sounds like the way to go
I don't have any pics of the whole exhaust system, sorry, and I don't have a lift so it would be hard to take them, honestly, find a good exhaust guy and all your problems will be solved, a good exhaust shop should be able to route it just fine, here a few pics I found, HTH.....
noah
interesting.... flexible tubing around the oil pan area and rear tank. curious, is that because pipe could not affordably be bent to do what was desired or becuase it would allow access to areas that might need work that a hard pipe would make difficult?
ah my bad.
I just today took off some tough flexible tubing from my auxillary tank neck to the fill spout (to make the bend) and it looked so similar from this picture - even with the hose clamps, pattern, etc - so I thought it was some flexible exhaust tubing....
heres a pic of my old dual exhaust down the passenger side of the rig since then have gone to ram horns ,y pipe single exhaust , actually think the truck runs better with the single , 2 1/4 y pipe into 2 1/2 single , heres a link to when i switched to single more pics
it will go down the passenger side if you use a rear dump manifold + a 2 inch bodylift very close to t-case tho
https://forum.ih8mud.com/showthread.php?t=47645&highlight=exhaust
