FJ40 DIY Front floor mat
I have a 71 and would love to have the mats that go all the way across hump in one piece but they are so darn expensive. Anyone diy them? I don’t mind the work. Just can’t think of a good way or material they could be formed to the truck. Thanks in advance.
T
Do it modular, as in in pieces.
Horse stall mats, cut em to fit
Have you done this? How did it work out? Might be kinda thick around the accelerator pedal don't cha think??
Like a redneck governor for the carb.
It’s actually not bad, I think the linkage bottoms out before the pedal bottoms out on the floor. I cut it to fit around everything on the floor, it does not cover the hump at all.
I used the pre-cut foil backed insulation from CCOT (~$34) and used it as a template to cut out a full length floor mat out of a PVC treadmill mat I got off Amazon. Worked well
I use to get good quality solid rubber stall mats from Tractor Supply. Now my local stores only have the kind that are rubber pieces glued and or bonded together. Not the same quality as the old ones and somewhat stiffer.
I just made a couple mats for a Gozzard fiberglass tub. Used these mats from Lowes.
Made template from paper, then to cardboard, then to mat. One mat did both sides. Second mat for rear bed area although it is just a little narrow.
Is the place run by a crazy helicopter pilot Viet nam vet?
He runs with an interesting team.
I pity the fool.
I’ll check it out, Ryan. I’d like to cut some nice ones for my Tundra as well.
The stuff is thick, like 3/4” thick. Good for the 40 but I don’t know about a Tundra.
T
The factory floor mat for the 73-78 would not be a good fit in a 71. The hump is smaller and would have too much extra mat. I used in my 68 but installed a newer transmission cover when I installed a four speed. It was used in fair shape so didn't feel bad trimming it for the box.
That's why I opted to do a sprayed in bed liner on all my floorboard :)
That is not something I would do in the desert. Floorboard get hot enough from the exhaust without the heat I. Phoenix. Would think it would get soft under your feet. Would have to cover it from leaving goo on your shoes.
Using Weather Tech liners in my Sequoia. On my 1st gen Tundra used the factory all weather mats. Those are good quality. After
Toyota's sticking gas pedal fiasco the new all weather mats are trash. Running 100 series all weather mats in my FJ62. Actually a good fit. Saying Land Cruiser is a nice touch.
