FJ40 disk brake conversion parts?
N. California
A couple of years ago I had someone do a disk brake conversion.They did it with a non vented disks.So im assuming that it was a Toyota mini truck parts.I need to replace the tie rods.So my question is,what years of mini trucks are usually used?The tie rods have a smaller diameter thread than stock Land Cruiser ones do.
It's really hard to guess what you got. Pictures may help. Why don't you ask they guy who you paid to do this what he used? I document stuff like this in the likely event I need it again somewhere down the road.
If non vented rotors, yes, minitruck. The steering arms are most likely minitruck too. Look to see if someone has pressed in the starter bushing deal. If so you prolly need a 40 tie rod end, if not minitruck. One suggestion may be to call someone like Marlin Crawler. He supplies this stuff/makes HD tie rods, etc. Another may be to go to some local supplier that can lay all this out of the counter for you to physically compare with your junk.
I'm told the 1979-81 mini pickup front disc brakes can not be upgraded to the 1986-newer vented rotors and calipers, but the 1982-85's can be upgraded.
I believe the 79 to 85 mini parts are the ones you can upgrade. I used 4 runner rotors and 60 calipers from mid 80 models. the runner rotors are vented and the 60 calipers are a bit larger and two piston for better stopping. IIRC
Drum brake FJ40/55 conversions to minitruck disc brakes can be done many ways. Disc brake donor parts from solid-rotor 79-85 mintrucks is one way of doing it. 60-series parts also can be used but I have no experience here.
Be carefull though, 79-80 minitruck donor parts require 76-78 FJ40 rotors while 81-85 minitruck donors use the later +79 rotors, they differ in how the wheel studs go through the hub/rotor.
Edit: here's a link to a past thread discussing this difference. I'm looking for a better one I know is out there with side-by-side pics and will post up the link if i can find it. https://forum.ih8mud.com/40-55-seri...oung-mini-truck-fj40-disc-brakes-convert.html
The shop that did the conversion is closed.And local auto parts didnt have any in stock.Here are some pics.This is either end of the tie rod.It has the same diameter as a stock FJ40 tie rod ,then tapers down to the same thread size of the tie rod end that connects to the center arm.Hope thats not confusing. Thanks for the help
looks like landcruiser stuff, they may have reamed the mini truck arms to accept the landcruiser tierod ends?? or used big pattern landcruiser arms.
if both ends fit and have the same pattern as the center arm...order landcruiser stuff
mini truck doesn't use the double end on the pass side....I think
If your got solid rotors from a mini truck the calipher looks the same as a calipher with vented rotor except the gap in the rotor is smaller to suit a solid rotor, the vented rotor is to wide and won't fit in.
If you can get the vented calipher they bolt straight onto the axle as the bolt patern is the same as the solid rotor calipher.
1. That steering rod is from a VERY EARLY landcruiser. You can tell from the fact that the end of the tube tapers down; all the 'modern' ones have a single [larger] diameter. YOU SHOULD UPGRADE THAT STEERING ROD RIGHT NOW.
2. Chances are if they used 79 and newer LC knuckle arms, you can just order standard LC tie rod ends for them. They will NOT fit that antique steering rod, but will fit the NEW one you should have.
3. That steering rod was safe for a 29" tire and manual steering. Chances are you don't have either.
Best
Mark A.
The mini truck and FJ60 T\R ends have the same taper. The FJ60 end have a larger diameter thread (23MM) and much heavier tie rods. You can use FJ60 ends but you'll need to upgrade to heavier tie and relay rod. The FJ 40 relay uses a 17mm thread where the FJ60 use 21mm. What steering are you running, saginaw?, stock?
Best
Mark A.
Ditto, MAF sells a heavy duty tie rod and relay rod that will accept a FJ70 series tie rod end replacement kit. Perfect for an FJ40 upgraded disc front end, either with mini or FJ60 knuckles.:beer:
you can buy ifs calipers and then buy vented rotors they workhttp://www.off-road.com/trucks4x4/article/articleDetail.jsp?id=186135
Thats what I did.. I uesd to have the mini stuff... the bought landcruiser vented rotors... and Ifs calipers and it all worked for me...
......Another may be to go to some local supplier that can lay all this out of the counter for you to physically compare with your junk.
Sadly, the first words out of their mouths will be, "Make, year, engine and does it have air conditioning?"
Look for an old parts store with older people working there. They may have been around in the days when they pulled parts by sight, not from what a computer told them. I needed a part for a small black Chevy a while back. The young kid was paralyzed because I didn't know what year the engine was and what it came in. I've pretty much had to settle on telling them it's a 1980 Blazer without air to get what I need. I don't change my oil anymore, and what's worse is the eyes of the kids at the Gypy Lubes glaze over when I try to tell them it's a 71 Toyota with a 350 Chevy and 79 tranny and transfer. I take it to the Toyota dealer, who has my specs on record in their computer. No problem.
But I digress. Another alternative might be to visit a wrecking yard that specializes in Toyotas, and see if they can identify it. They might even have replacement parts cheap.
