Usually the goal is to preserve the factory coating. Looks like you may need to get more aggressive with the rust on this one. I like and have used “rust dissoving gel” made by permatex and loctite. It’s a pink gel that used to be called Naval Jelly. Slather it on the rust and use a tooth brush. It’s basically a mild acid. You may need to do a few rounds on the cast iron base. Guessing the primary/seconday shafts are seized. You could also soak it in evapo-rust if that’s the case. Let it soak, gently tap on the shafts, soak some more, ect. Take your time and the shafts will break loose. I wouldn’t recommend removing butterfly screws if possible. They are staked and a nightmare if the heads twist off
Soak the bowl bowl and air horn in a gallon of “Berrymans” carb dip. On a cherry carb you’d just want to use a toothbrush and berrymans. On this carb you could use fine grit waterproof sandpaper to make it look snazzy. I also have used dremel EZ-Lock buffs on a badly pitted carb. Pin_head has a video on Youtube that is helpful. Take your time during diassembly. On my first carb I took lots of pictures as I tore into it. I also kept small parts seperate in red solo cups and wrote on the cup where the parts came from. Now all the parts just get tossed together because I know where they go.
When reassembling, do not over tighten the sight glass or it will break. Also don’t over tight the fuel inlet fitting, not fun if they get stripped.
I recommend having a Haynes manual or FSM. I used my Haynes quite a bit to set my carb, i.e. they primary angle at which the secondary kicks in. FYI the Haynes float height setting is wrong though. Microfiche has a good exploded picture of what parts should be in your carb.
Link to fiche:
http://www.globalsoftware-inc.com/c...he_Parts_PDF/FJ4x_FJ55_B40partsMicroFiche.pdf
The advantage to sending your carb to 65swb45 or fj40jim is the would know what’s missing and have the spares.
Pull vacuum on your choke pull off, if it sucks in and holds you are good.
Test the idle fuel cuttoff solenoid by hooking juice to it while removed. Measure how far it retracts. Believe it should be about 5mm. If the magnetic needle is gummed you can squirt carb cleaner in it.
Cruiser Outtfitters has Carb kits.
