Fj-40 Will not start PLEASE help..
Yes of course a huge area, but I can narrow it down, she is a 1978 fj40.
I was driving along and then she started to sputter. I'd floor the gas and she was still dieing got a lucky roll down hill and downshifted seamed ok. Then went 50 yards or so back fired and died. I can turn the key and it cranks but no fire to start engine. Going on the list of 3 things you need for it to run.
-First fuel-
Fuel of course was my first guess. Checked the pump, was making the little noise when I turned the key, so check ok. Next went to the carb dumped gas in it still not start. Bypassed the fuel filter with a ball point pin hull. (very MacGyver) fuel was now for sure getting to the carb as I cranked it I could see the fuel. Fuel ok I guess.
-Second Spark-pulled the plugs grounded them and got spark on all plugs BUT only two were bright and blue rest were dull orange. But I had spark.
-Third-Compression I could feel the air from the cylinders as the engine was turning.
Last me out of ideas…seams like she is getting fuel spark weak but there and compression…Any thoughts? I was told to check the "points" but does a 78 have points? Could the carb be plugged up inside? Could my rings be bad? Could the timing gears be off? Anything else could be wrong?
Thanks guys for the help!
-Thomas
Could be the carb but, My 75 did that a few years ago and it took me forever to figure out what the hell happened to it, Turns out it was the damned battery cables, the ground especially was in poor shape. I replaced both cables and she fired right up, no problem...
could be a plugged carb. if the filter was blocked and you punctured it the foreign material in the filter may have passed into the carb. An easy way to add fuel is to use an empty contact solution bottle. the tip is small and meters fuel better than using something like a plastic cup.
I would personally look into the timing though. A weak spark may not work under compression. I'd bet that is the problem, though it's hard to tell. Might test/replace the coil and take the cap off to see how the inside components look. A visual inspection may find broken parts in there. Then check the points if it has them, or just replace them. I don't know if yours has them or not.
It would be odd to lose compression all at once in enough cylinders that it wouldn't run.
I would also have to guess timing, as it is not all that likely that an electrical connection went "bad" while you were driving - not saying that it couldn't have been bad before...
Was it raining? did your distributor cap get water inside? How is the inside of the cap & the rotor in the distributor? Pop the cap off and have a peek. I have also had plug wires break right at the point where they contact the plug - fresh from toyota.
check your battery, if its weak maybe you arent getting a spark. maybe your alternator is going which is sucking your battery. does your starter try and turn?
ignition fuse?
most likely not timing.at least the not the gears.these rigs just dont jump timing unless there is something internally seriously wrong and there is not ,that it sounds anyway.points maybe,bad wire happends all the time.how is your gas.is it halfway up the float bowl sight glass.which by the way its in the front.did you blow through your fuel filter,did any junk blow out.start with your coil.maybe the secondary is going out
OK just bad luck?
So after hearing every story you could imagine, (the best one was the local Toyota dealer said my timing belt must have broke, of course they don’t have belts...I ran away:eek: ) I checked '78 is the cut off so I have electronic ignition. Great no points not the cheep fix. So just did a “tune up” just to see what would happen. I have less than 5k miles on the last one but 4 years time on those miles, so did all the stuff. Cap, rotor, plugs, wirers and new fuel filter. Turn the key starts on the first try. Only thing I can figure is the spark was too weak? Of course I had to pay $150:crybaby: to get towed home to figure this out...Oh well thanks for the help all great people here!
-Thomas
Glad you got 'er runnin'
Reminds me of problems with my former rig, 74 FJ40...
...let's just say, was taught by my buddy the farm-boy just what the hell a "Ballast Resistor" is. Fuel was there, spark was hot, did tune up and the works, no go. This ugly little part had me scratchin' my head for a few days. (more like close to a week but that was before internet and these great guys at ih8mud.)
Like I said, glad you got your rig runnin' !!
The only time my cruiser ever died and left me stranded was because the coil died internally on a road trip.
Like koolhand, I learned about ballast resistors, and now I carry a spare coil in the tool box at all times even though I run a pertronix setup to get rid of the problematic points.
Cheap hint...if you have a jcpenney card, join their auto club. Free towing up to 100 bucks, costs 6 bucks a month. Also with amex it's now free up to first 100 bucks.
9 times out 10 it's ignition.
timing
I lost a lot of power one day and it turned out the hold-down for the distributor got a little loose and timing got a little retarded. I got out the timing light and set the timing again and everything was fine.
X2 check battery
I had a short that would make my cruiser cut off and backfire. It was only when I turned on the lights or turnsignals.
