- Joined
- Nov 26, 2014
- Threads
- 5
- Messages
- 29
Hello all, I got a challenge for you! I have a 1976 FJ40 in Nicaragua, i say that to preface the fact that anything goes, take nothing for granted when pondering the cause of my issues, and parts are very hard to come by. I was noticing a loud clunk in my rear end, so I propped it up and found my driverside axle had about 1/8-1/4 of an inch of moved in and out. There was not play on the bearing up and down, just the axle could slide in and out freely. My mechanic found a new bearing, seal and put a new race on the axle and solved the problem. He decided to put a slightly wider bearing and forego putting in the washer behind the bearing... did this without my knowledge and too late to change it. Seems to have solved the problem. He then purchased an original bearing, washer and seal for the passenger side, and now, that side is doing the exact same thing with a good 1/16-1/8 of an inch of movement that makes a very loud clunk. Is some movement normal, and more importantly what is the quickest, most reliable fix. My mechanic wants to open up the diff, and put a washer between the gear and the C Lock washer.... Thoughts? As long as the C lock is not in danger of slipping off the axle I think it could be a fix. Please let me know if anyone else has had this issue.
