- Joined
- Jul 22, 2012
- Threads
- 641
- Messages
- 17,911
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Yes*
We found a 20 ft-lb increase in torque over a vac-advance (DUI) setup. All in the low & midrange where you most need it.
Real, tangible benefit: we can increase timing in the area below idle speed, which has the effect of giving your engine an extreme will to live when it might normally stall. Taking off from a stop and crawling on the trail at idle speeds require zero to little throttle input.
*computer controlled ignition requires professional dyno tuning to extract the full, measurable potential.
What fuel was this on? now I want to max out an F135 with this and the single barrel Autolite Sniper on ethanol
