Finally bought an 80!!!
congrats!!! hell of a deal!
Did as instructed and I saw three sets of diff lock lights as well as the abs light. I heard the sound too so feeling a lot better. I know I am due for a birfield job but if you guys can take a look at this picture of the wheel area and let me know if there might be major damage...
I also took a picture of the radiator...it looks like the hose was replaced fairly recently.
Did the front and rear diff lock lights (on the right side) blink or turn on and stay steady? If they are blinking (which means you were good with the timing of the picture taking :)) then the lockers are not locking. If they blinked and then were steady you are golden. Many folks (me included) try to exercise the lockers on a regular basis even if that is just a lock/unlock exercise in a dirt lot.
As for your birfs/front axle, given what you said about the PO I'd say they've never been touched (unless you can find records) and would plan on doing that soon as PM. Hard to tell from the pic but the knuckles look dry and caked and don't look to be in great shape. Probably no damage, just need to service the front axle and maybe plan on putting in some new wheel bearings etc.
On the radiator, is it leaking? Seems like maybe it has a leak near the top seam or something.
Oh, and you probably need to start reading up on the FAQs re: maintenance and try to do as much of it yourself as you can. If you have to pay someone that $1500 you allotted won't go far :frown: - A dealer will charge you more than that to do the front axle service alone and they won't do near as much as you should do, and can do, yourself for 1/2 or less of what they'll charge (not to mention that you'd get all all new parts :))
So much info...this is going to take forever
There is so much info on this forum...I'll never get around to reading it all. I already spent a good two hours reading the FAQ.
I just bought some Royal Purple gear oil to change out front/rear diff oil, as well as the transfercase (expensive!). I figure I should start with the easy stuff and work my way up to the birfs (scared of it now...must...build...courage).
Corsair23: The lights were steady! :clap:I'll be sure to test the lockers regularly! The radiator seems to be leaking from the top seem (feels like plastic???). I don't smell or see any measurable leaks. Taking it to the shop this weekend to get it checked out. Just found the receipt for the hoses that PO replaced.
Someone mentioned "bus tranny"...the build plate states A442F...so I am guessing I have the aforesaid tranny? I did some poking around in the forum and the general impression is that it's not a bad thing to have this tranny.
Regarding wetsanding...how much would that run?
Thank you all for your kind welcome. All my other hobbies are slowly becoming just a faint memory...
Before you wet sand your hood, you might try something else first. I would use a "clay bar", you can get these just about anywhere...WalMart, AutoZone, etc. It's easy to use, you simply spray on a liquid (comes with it) that's like soap...it makes the clay bar move easily over the painted surface. You simply rub it back and forth without exerting too much pressure. It should remove most of the contaminants and oxidation without removing the paint...wetsanding will remove the oxidation and then immediately begin working away at your paint. If you're not careful you can sand right through your paint.
If the clay bar doesn't work I would try a mild oxidizing cleaner...basically a mild rubbing compound...remember, the more grit the more you remove...remove too much and you can't put it back on without repainting. If you use a power buffer, make sure you don't put the edge of the buffer to hard into your paint or it will burn through the paint...similar to sanding through it but it harms the paint with the heavy friction and heat...once the paint is burned you have to pretty much repaint. As a kid, I waxed a neighbors Lincoln Mark V (Bill Blass Edition), the blue and white model...with Johnson's floor wax....in the SUN...did the entire car all at once...the wax would not come off...the entire car, particularly on the white areas of the paint had a very, very bad orange tint from the floor wax. I panicked...got a drill with a buffing wheel and proceded to burn the $hit out of the paint all over....black swirls where I got in too hard.
Uh oh...the owner comes home...isn't really happy...but paid me regardless...I tried not to accept payment but he insisted. He told me he wanted a new car anyway...he traded it the next day. I got most of the orange tint out of the paint by using laundry detergent and hot water...it still looked bad...you could still see the orange tint and burn marks all over. A year later I was able to charge over $200 a car when I was detailing cars (I finally took the time to learn from a pro how to do it)...that was back in 1980...so figure I've learned a few things since then...thought you might enjoy the story.
Thick dark oil from front differential...major issue?
Land Cruiser - Windows Live
Changed the rear diff oil...pretty clean but found some metal shavings on the drain plug magnet. I don't think this was changed since 230k miles ago.
The transfer case was clean, a little dark, no issues.
Now the front was weird. It was thicker, darker than the others. Almost paste like. It drained slower. When I filled it back up, it only took like 2 quarts. Is this a sure sign that the seal separating the diff oil and the birf is gone? I took a picture of the thick oil (link below) for your input (oil is on a yellow sticky note). I hope I didn't waste two quarts of Royal Purple gear oil just to get it mixed in with bad oil.
I did the oil change at the auto craft shop at Fort Gordon and the mechanic on staff said that it's normal for oil to be like that if its 230k/16 years old (not sure how true).
Thank you all for your help and the warm welcome!
Thank you all!
Looks like you may want to do a front axle job in the very near future. The big ball there should have more grease on it (you can see a bit of grease on the bottom 1/4 of it). Until you do the job, you may want to squirt a tube or so of grease into each axle through the service plug to be sure everything stays lubed.
Hard to tell what's happening with the radiator picture.
What's that sludge in your last picture? Did it come from the axle?
Edit: I guess I should keep reading.
That sludge looks like it could have moly grease in it. Or else it hadn't been changed in a very long time. I'm sure someone else with more experience will chime in to give you a better diagnosis.
Looks nice, I bet that oxidation would come out with very light wet sanding and wash/wax
Nice rig man, you got a killer deal!!! I agree on the wetsanding, should come out.
More than one person is telling me that this is damaged paint, and cant be sanded out...
Not to hijack, but mine is dark green too, it seems like the most common color for this kind of damage
:flipoff2: You obviously have some pm to do. Take your time and bite off little bits at a time and you will get it done. If i was unable to buff and" re-clear coat" the hood I would "black it out" with some sexy flat black paint. :flipoff2:
the radiator is most likely factory original and its cracking- replaced mine for the same reason, it is plastic tanked top and bottom; all the hoses, cap and thermostat plus the rad were ~$500 including shipping from CDan (the guy here for oem parts)
good luck- FWIW you got a great deal, but should figure on a couple grand in PM soon.
The hood does not have oxidation, it has a burned topcoat, that will not sand out or buff out. The only cure is to strip and repaint.
You can get it to look a little more presentable by rubbing some sort of glazing compound on it (buy at a detailer's supply store), but it will last only a few days. ATF (believe it or not) also works, again only for a couple days.
You have a front axle rebuild in your future! don't worry about it, it's not that hard, just gather all the parts and tools together, do a lot of reading on the procedure, and allow a couple days to take your time and do it correctly.
The radiator needs to be attended to. You can always buy new, but if that's got the copper core (as opposed to the aluminum), you have the option of replacing the tanks on the old core, and having the core rodded out. This will cost quite a bit less than a new OEM radiator, but will end up as good as one. There are aftermarket solutions, but they are short-lived.
Congratulations, you got yourself a nice truck at a good price.
