Finally bought an 80!!!
Ellicott City, MD
After a month of looking and a couple of disappointing views, I finally found a 80.
1994, 230k, dark green, grey leather, cracked front seats, dealer serviced, HHG done but don't know when the birfs were serviced. Dealer replaced front/rear rotors 15k miles ago. Oil pan gasket was replaced (guessing there was a leak?)
Does have lockers, put her in lo and turned the dial but no sound (should I be hearing something?). I do see the red diff warning signs.
Driver seats don't slide well and the windows have a hard to rolling up and down (but still work).
Paint on hood and roof is oxided but no rust!
Runs and shifts really well. Just did an oil change with 10w-30 with RP filter ($60 out the door with militar discount)
I paid $3500 (hope I didn't get ripped off but I felt very comfortable with he purchase!):)
The experience of actually driving this beast is so much better than reading about it here! I never knew how high you sit up when driving.
I just want to thank everyone for helping me and guiding me with this purchase. Any recommendation with baselining is of course appreciated. I found a pretty good shop with a master tech (I live in an apartment without a garage!). I am budgetting $1500 for PM with labor going about $40 per hour. Pictures to be posted soon!
Congrats!!! Now :flipoff2: and
Definitely didn't get ripped off (unless there's a major problem you don't know about). I've got a 94 with 230k and I love it. You'll probably want to eventually baseline everything and do all the major maintenance items like the front axle, rear axle, etc. You should try to do as much work on it yourself as you can. That way you know it was done right and you'll save lots of $$$$.
Welcome in :flipoff2::hillbilly:!
You got the best deal in the town with that HHG done and lockers!
Sound is not a big deal when you turn the dial ( me to I don't hear or maybe is just because of my music :hillbilly:) the problem is that you don't see that magic lights. Start to work on tracking the wires to the locker..... maybe is a wrong connection or somebody removed the lockers...... And about windows, welcome to the club you are not alone :D. My driver window need to be pushed up manual.
:cheers:
What lights should I be seeing?
I found a distressed seller. She drove 70 miles a day for work and judging my the all the receipts, the $900 brake jobs, and $300 oil pan gasket job was killing her, let alone the fuel cost.
She had the dealer put in new window, regulator and rails (?) exactly a year ago but the driver side window is still struggling. I wonder if a local Toyota dealer will fix this for free. PO paid almost $400 for that job alone.
As far as the lockers, I remember seeing one light with the front wheel turned and the second light without the front wheels turned. I just assumed that there would be sounds based on slee's guide. What other lights should be on?
I really love this vehicle and I only had it for three days! I am contemplating selling my 2002 Acura RSX-S to restore my 80...
You have a photo with that lights? ABS light. Yes, you right need to be sound, my cruiser have a very low sound to the passanger side.
When was made your cruiser? Maybe you have the buss AT !
welcome:flipoff2: sounds like a great deal to me! yours looks exactly like mine when I bought it except mine doesn't have the magic dial. search under lockers, for help with you locker problem. have you taken it out to a dirt lot and tried to engage-disengage the lockers to get them to work, as others have suggested?
Dunno if you know or not, but in stock form you have to be in low range for the lockers to engage. In high range the lights will just blink.
Looks like a solid rig.
edit: eh, im stupid and didn't read completely.
My bet is the po never used the lockers and they need to be exercised. Take it in some grass, click the dial over and drive in a figure 8 for a bit and see if they engage. The first time I used mine it took a long time for them to work but now they come on pretty quickly.
bought mine's about a month ago and were having the same problems with the lockers. There's a lot of good info on the sites to trouble shoot the lockers. I used this one Troubleshooting the Toyota FJ80 Land Cruiser Center Diff Lock (CDL) | Pacific Northwest Backroad Adventures
I turn the crusier out and just shifting it to low and out of low and drove in a figure 8 and also back up then u can hear a clunk and the rear locker work.
As for the front locker, the wiring harness from the passenger fender wall to the actuator was missing because it probably came in contact with the exhaust piping and the PO just removed it because it doesn't affect the car.
Bought new harness and it lock right away so give that a try.
Looks nice, I bet that oxidation would come out with very light wet sanding and wash/wax
Lights and 4-lo transfer sensor
Looks like a nice rig. I had the same problem when i first bought my 80. Dash lights when you put it in 4-lo: there should be an orange light on the left, just like the red front and rear diff lights on the right, that indicates the center differential (in your transfer case) is locked. this should be accompanied by an orange ABS light to indicate ant-lock brake system is off while in Lo.
On mine, these did not light up when i put in 4-Lo. In my case, it was due to a non-functioning sensor on the transfer case. These sensors quite working if the vehicle is never put in 4-Lo.
First, try shifting from hi to lo over and over again to excercise the sensor. You might have to do this upwards of 50X. You don't need to drive it, just sit there in neutral and shift from hi to lo, from lo to high, and repeat, until you hear the relay clicking behind the driver side kick panel. You should get the indicator lights if you can hear the relay.
If that does not work, you will have to get under the rig and test the sensor. I think you can use a paperclip to "jump" the two wires on the sensor plug, which signals the ecu that the vehicle is in 4-lo, you can use that method to see if your dash lights work, and then test the front and rear diffs.
Pm me if you have any questions. I spent a lot of time playing with the actuators just to find out it was a simple switch problem.
Enjoy the new rig. :flipoff2:
awesome deal. welcome to the addiction.
Lockers working...I think (links to pictures)
Did as instructed and I saw three sets of diff lock lights as well as the abs light. I heard the sound too so feeling a lot better. I know I am due for a birfield job but if you guys can take a look at this picture of the wheel area and let me know if there might be major damage...
I also took a picture of the radiator...it looks like the hose was replaced fairly recently.
Land Cruiser - Windows Live
Thank you all!
Good looking PIG:) Will follow to see future mods. Cheers.
