Fender mounted mirrors
Japan
My mirrors are shot- 81 JDM model with huge plastic rectangles on the fenders. They work well enough but- well I'm just trying to figure out what the reason for mounting them to the fender is. You can see your running boards in the mirror- that is nice for the pass side if your getting into some tight spots. But otherwise they seem to be a step backwards for on road use. they need to be replace because the plastic is cracked and I'm wondering if I should just go with some door mount units instead.
Thoughts???
pete
It was Japanese law up until the mid 80's
No blind spots. (Smaller picture but wider field of view)
Japans streets are narrow hence the need for mirrors closer to the body lines
The advent of the electric mirror killed the law.
I actually like the ones on the 55's
Here's another.. looks like from some Japanese brochure..
attachment.php
I'm considering going to this fender mount, because my passenger side mirror is pretty much useless due to my roll bar blocking.
I wonder if the mirror mounted here bounces and shakes a lot? I'm tempted to try it, but don't want to drill into my front fender.
I'm not sure I could drive around with mirrors like that even if they were stock. It's embarrassing. Looks like something that was put on with no thought behide it. AND... Anyone who likes them and or runs them right now, I did not say that, I don't recall ever saying that...
That Japanese brochure shows a chrome bezel and bumper. Don't think I have ever seen one on the site, does anyone own one?
Your looking at the luxury model two of my 41s had the chrome bumpers but not the bezel,,,.the mirrors on the 55 were also used on the 70 series
The plastic that is cracking on your mirrors is it the base or the mirror heads , I tried to get some from Japan but some of the parts are no more if you are lucky you may find some in NA from someone who has pulled them off... try 4wheel auto or SOR.
By the way I love the fender mirrors thay have a look of their own you get used to as long as you have the regular size heads and not the elongated ones...no shaking issues that I have experienced only when the heads start to crack.
If you're looking for a new option; my PO used Jeep CJ-7 side mirror mounts on my '75 FJ40. They bolt right onto the hinges with no changes to the bolt holes on either the mounts or the hinges, and, they look like they belong there. Visibility is great; if you go offroad and are worriend about limb catching, loosen the bolts, and swing them in (forward or back). Plus, even with the doors off, the mirrors are still there, unchanged.
Just my $0.02
Mine came with a set. Most of the chrome had flaked off both by the time that I got to the rig. If you, do a search you see lots of shots of the combo. I elected not to have these things "re-chromed" which you can do here. Aside from not liking the look on an outdoor oriented rig, it somehow feels like something environmentally and health wise wrong has to be involved in paying a guy to sit around an work with liquid chromium.:meh:
Thanks for the input guys- for now I'm going to see if I can find new heads. Its the pinch that is cracked so the ball is loose in the socket and the Rt side mirror slowly moves- and yse they are a PITA to adjust.
My truck is exactly like the one in the brochure (same color too) but its a 44 (i think the one in the pic may be a 46)- no winch. Chrome bezel and bumpers as well as wheels. But all the chrome is shot.... I think I like paint better anyway.
And with the diesel the mirror vibrate like mad at idle. I have to rev the engine a bit just to see clearly.
In the end I think I like the looks of side door mounted mirrors better overall. Its just a cleaner look. But one nice thing I've found about the fender mounted units is that you can check how close you are to the edge of the road without taking your eyes from the direction of travel. One down side is that the drivers side mirror actually gets in the way when your looking to see where the front is aimed in a corner.
So I figure looks aside is 6 or half a dozen. For the short term I'll look for some heads (and yet I have the larger rectangular ones fitted now)- and when get around to pulling the fender for rest repair etc I'll re-consider.
I will buy the brackets and arm assembly off you if you ever swap to door mirrors.
As for the heads dont buy the convex from COTs they wont fit the ball the socket is to small I ended up buying from Japan at a $100 for a set Japan 4x4 in the vendor section pricey but worth it to me.
Thanks D- I'll try reaching him again. I sent an email once but no reply....
I may just head over to the local dealer and see what I can find.
Japanese model, 1970 rhd..:D
off topic question,does that emblem its factory size? for that year maybe in japan? dont know too much history of this 1970,just curious
It seems to me the fender mounts would be in the way of working on your truck. I personally like hinge mounts.
You can get the flat glass version local but the vision on the flat glass is crappy compared to the convex.
Skidplate with any kind of lift it is difficult to work from the side for most people plus the JDM mirrors fold forwards or backwards out of the way if needed.
Eshu that emblem is not stock that I am aware of it looks to big
Dieseler- got a part number on those mirrors?
P
