Build Farm Fresh LV
Here are some good pictures of an original.
Ahh, That would explain the bumper having a curve to it. I thought it had just been bent but when I really looked, it has a curve along the entire bumper. And that would explain what look to be holes for a license plate mount. Hmmm...I could straighten it and use it? It looks much better than the plain steel.
I just drilled out and sleeved the hood hinges because they were really badly wallowed out. That went well but when I put the hood on, it is really out of alignment? Anyone else have this issue? The hood does not appear to be original. The gap at the windshield is pretty consistent and the drivers front corner is flush but the passenger side front corner is sticking out almost 5/8"? Hood is the same side to side and then I measured the cowl. From the hood corner to the end of the cowl is 8" on the driver's side and 8.5" on the passenger's side? So were the LV hoods custom made? I went and measured the other parts LVI have and it is the same!? Has anyone else noticed this on their LV? Do I just modify the hood to match?
I was actually able to drive the LV around my parking lot though! I had to get a big piece of machinery out of the back of my space and so the LV had to be moved. I sat on some blankets with a box behind me for support. It was awesomely tantalizing! Got into second gear in with the trans very quickly. The 5.3 has some nice pep! Brakes were good but not very powerful? I am pretty sure it was due to the fact that I was not completely full of fluid yet. Man I cannot wait to get this on the road!!
That went well but when I put the hood on, it is really out of alignment? Anyone else have this issue? The hood does not appear to be original. The gap at the windshield is pretty consistent and the drivers front corner is flush but the passenger side front corner is sticking out almost 5/8"? Hood is the same side to side and then I measured the cowl. From the hood corner to the end of the cowl is 8" on the driver's side and 8.5" on the passenger's side? So were the LV hoods custom made? I went and measured the other parts LVI have and it is the same!? Has anyone else noticed this on their LV? Do I just modify the hood to match? View attachment 1847462 View attachment 1847463 View attachment 1847464
I’m certainly no expert but I had a similar issue on my LV. I ended up loosening the bolts that held the fender in place and the bolts that held the hood hinge and was able to shift things around to get them to line up. I suspect this will work for you.
Keep up the great work!
What's the wheel paint? Brush, spray? Is that fill and sanding in first pic? Very nice job.
