Build Family haulin'
Too late. Order for H1 12bolts, pressed centers, rock rings, and 37 military goodyears is paid for and being shipped out. I'll have to stomach new tires some other time. I too like the 40s but 17" double beadlocks weren't in the picture. Unfortunately the 37s are radials but they should be better on the hwy and I do log some miles on the hwy.
Oh yeah, I just won a Holset HE351 VGT turbo pulled from a 6.7 cummins on ebay for cheap, but I'll save that for down the road.
Mike, let me know when you sell the rims. I may be interested, I need a second set.
Great choice of tires Mike.
I am running my second set after four years as my daily driver.
They suck in mud, but do well in other terrain and wear like iron!
john
Hopefully a little additional grooving will help with mud performance. Did you get yours balanced? How's hwy handling?
I like the 40" MTR looks too .. but are pricy those days .. but they are 13.5" wide .. aren't ?
You need my beadlocks. I have a set of wheels coming in nthe next week or so. ;)
john
mmm just what you need in the north wet. a tire that sucks in the mud! jk. I think the siping and or some grooving will help!
could be 13.5. but either way they are a great looking tire. Mike def has enough room for them too...
Clint
I asked you about them in my thread but you did not respond. PM me with what you're thinking.
No balance at all.
Slid the tires onto the beadlocks and kept the torque @ 25ft pounds for a few years and honestly, I have not done a thing for a while.
The tires wear like iron and 70 mph is a decent ride for a locked wagon that is sprung over.
Whoodathunk?:grinpimp:
Clint
I'm little afraid to ask .. but how much they cost right now ?
years ago my 37" was around 175ea ..
weekly update
Like posted before I've got my rims and tires figured out and on the way. I'll update those when they come.
In the meantime I decided I at least needed some kind of tach. My intentions are to figure out how to use the factory tach but since I haven't been motivated to get it going I bought a tiny tach for a quick long term temporary fix.
This is the diesel version and it replaces the internal battery with Flash memory which mean it'll store the counters but needs external power. I was asked how many cylinders so it reads correctly.
This is the sender unit. It picks up the pulses on an injector line.
So the red wire goes to the sender and the white wire needs to be grounded. I found a spot, drilled a hole on a bracket and attached it.
I tested a few spots for a 12v source and found this one that was switched right on the back of the factory tach.
Thought about velcroing it but just put some screws in it to keep it secure. I removed the factory tach, passed the tiny tach through the hole for wire routing and then re-attached the factory tach.
Here it is with the panel installed and the engine running. I still have the protective plastic sheet on the tach but the tach reads the rpm when started and reads the total time running when the engine is off. It also has two service count downs if I wanted to use those for service intervals. Pretty quick and painless.
While checking the lug nuts on my spare I found the driver side TRE was toast. Local fj80 TREs were cost prohibitive so I ordered some from Marlin and will be driving the car to work this week. I ordered two (a lt and rt) to replace the tie rod TREs even though the passenger side looked fine. I pulled the front bumper, sanded it and shot some primer on it to keep the rust away.
Sweet. Are you planning on DD'ing the H1's? I don't know if they're legal in my state, but I thought running beadlocks on the street was illegal everywhere. Maybe it's different for these military rims:meh:
I do plan on DD with the H1s. I guess we'll see if I have some picky law enforcement here or not. With enough false beadlocks around it's probably not going to be a main reason to get pulled over.
I drove with my TR beadlocks on all the time around town and to work and never had a problem. Even had a police officer tell me cool "jeep" one time in a parking lot with them on one time. I bet the average officer couldnt even distinguish an h1 rim from a regular steel rim.
