good inputs, I decided based on the work involved to cut. Forgive the many pics but I'm hoping to archive pictorially what living in the past and mark have been saying on proper removal. First pick is a lip I cut back on body to get the rear plate and bearing off here's process of removal based on the good stuff already posted:
1) drain remove bottom of fairly. See my pic, now I know why she was "singing" in high
2) remove 6 bolts on back of plate to rear of fairey. Note pic, I had to shave the lip of body by about an inch to get it out.
3) stick long 1/2 drive extension into center of gears and unscrew it whole rear minue shift fork and front gear can be fished out through rear plate now
4) remove 2 internal black bolts inside fairey that are easily visible from underneath, the remove the 3 nuts above unit. Yes, these are nuts
5) here's where I'm a bit confused on some of the posts, some indicate the clip holding input gear can be removed through the pot access port and other posts indicate transmission must be separated from tcase to get to retaining c clip. Any help here would be great
