Sorry for that, first time I had to have my HJ at 4100 rpm for three seconds was just a big mental heart-attack.
But after 4 years / 280.000 kilometres it still has no problem whatsoever with the European full throttle test (far below 2.0 max, 2.5 for turbo)
What I know of, to limit the particles:
-start engine and spray water in exhaust,also with high pressure=loads of black stuff removed
-use shell expensive diesel (makes land-rover test go from 4 to 2.0)
-use 30 % veggy oil or more= a lot less soot
-use 2 liter of atf in the diesel to clean inside
-use 2 liter of gas in diesel to clean inside
-rev the crap out of it to clean engine, lol is the word crap allowed nowadays
-make sure engine oil is new, fuel/air filter new.
-fill new filter with additive but that is a trick that lasts for a minute (but is done here)
If that does not help your engine needs a rebuild?
Good luck, If all specs are factory it should pass for many years.
