Factory?
Eureka Ks
Is this supposed to be like this I know mine Is made from many I think I have a late 73 cowl ,frame , and mechanical with a 76 tub
thanks for any help
I'm gonna say no.
The tub that you have appears to be 74 or earlier. They welded the extra brackets to allow for a newer style door (75-up) which take a different style striker.
My tag says Dec 73 but I have ambulance doors so all my doors must be 75+ I have a wierd weld were my front cowl meets my rocker panel made me think I have a different tub altogether
Looks like Baron Von Frankencruiser was at it again. Good thing there is a lot of interchangeability between years.
The holes in the actual body pillar show that the threaded portion has come loose and slipped down. If it isn't rusted in place in the wrong spot, you should be able to coax the piece back into alignment to hold the striker in place if you decide to go back to the correct year doors.
It's just at the bottom of its adjustment.
It probably rattles around as it driven.
Maybe optical illusion. It looks like the threaded holes in the interior piece are not lined up with the outer unthreaded holes. I just meant that he'd need to move them up a bit to get the threads started. Also, I assumed they were supposed to be stationary and that my loose one had come loose. It makes sense after reading your post that they're probably supposed to be loose for adjustment purposes and that my stationary one is probably rusted in place. :doh:
I agreed with others... you have a ‘73 or older tub. A newer tub would have a bulge where the extra angle is welded on... and holes in the top of the fenders for roll bar mounts. I suspect there are also not reinforcements under the inner fenders for the roll bars.
It had and it does again have all the reinforcements under the fenders I haven't redrilled for the roll bar yet I have replaced the rear quarters and fender Wells and rear sill that's why none of that shows
These are the removed fenders
