Factory e lockers
Qld Australia
Guys I have read a few of the elocker links and most relate to 4Runners so not sure how different the housings in 80 series are. I note that all the 4runner write ups show grinding the actuator notch out and also adding material around where the extra stud holes are tapped.
I read "Boston Manglers" write up which showed in the rear that he only ground a little bit out and had to swap out the longer studs but did not mention tapping new holes or having to build up material for the sealing surface. This was however on the rear.
Is the front similar. I have a factory locker equiped model however the front housing is a little worse for wear. Someone has cut off part of the radius arm mounts and rewelded them fairly ordinarily. Also the swivel balls are rusted. I'm thinking the easiest fix will be to get a non locker housing and swap it all over assuming the front is as easy as the rear. not sure if I want to go to the same effort as the runner boys have to but then again locker housings over here are rare as and very expensive.
The front housing takes some grinding and longer bolts in a few spots
I put two TRD elockers in my 85 4Runner axles and it wasn't that difficult. If you want to get a really good idea of mechanically what might be involved then go to the dealer and buy the front gasket for both an elocker front diff and a non-elocker front diff and compare them.
