Factory 2f PS mount location
Northern Colorado
Wanted to post a pic here...
Thank You very much for posting that picture. Now I know I do not have the original block in my 79 FJ40.
and here is the PS pump that mounts to the holes, pump is the same as a fj60(if the 40 is a 8/80+) If its a 79-7/80 the mount for the air pump is different but the PS pump and PS mount are the same.
in this pic there is a 80 PS pump and mount and a 8/80+ PS pump and mount
run the block # at SOR
PabloCruise said:
Are you missing these? 79 and up should heve 'em...
I do not have those PS pump holes on my block. I just checked my engine number and it is 2F-246774 which according to the decoder ring on the SOR Web site makes it a a Feb or March 1978 production motor. So either Toyota put a March 78 engine in my May 1979 FJ40 since it did not come with factory PS or someone swapped the block (engine) at some point. Since I also have an early valve cover I am betting someone swapped engines on me. Not surprising as this 40 has had a few POs.
Thanks again for the picture.
Landpimp, Those are good PS pump pix, it does not look all too hard to fab a bracket to add factory PS if one had holes in the block.
Wes, I have been moving pretty slow on my 40. I got the Toybox in and am working on the SOA now. I will be ready by GSMTR that is my goal. I am sure CO is treating you well. I may come out and ski this year, I will let you know if I do.
while I am sure you could fab something up......the question would be why? you can pick up the PS pump and mount for $100 without alot of work........and it bolts on.......which if my favorite method ;)
Good tech, as a side note... Early blocks can be retrofitted with the holes, I know of several that have done so. One recently was the local Toyota dealership, they bought a 2F block from me, knowing that I didn't have any 79+ with the holes, they took it to a local machinist who added the holes.
Reason for the swap... oil change gone bad, even the dealership can ruin a good 2F :D
I would think if you had the mount it would be the way to go.
Trevor said:
What did the dealership use to locate the holes?
The block (with a hole in the side) and the mount... Any decent machinist should be able to make the holes, but be prepared for the price. Drilling/tapping cast by a machinist isn't going to be cheap.
I've heard it's real close to the water jacket. Of course i dunno if it's any closer than on a block with them. I can't go out and look at my bare block anymore, for that matter a 2f in a cruiser :(
I would just run a saginaw pump and buy the bracket but then again that's just me..
John, anytime your more than welcome to stay, although I'm not on the slopes. :mad: But I'll make some turns with you
Jacket schmacket! It's only water, right.
I remember 18 years ago, looking at my third leaking header gasket on my 68 and the lonely flange ends on the header that had no bolts in the head to secure them. Pulled the header, drilled into the head, tapped the holes and permatexed two studs in place. No more leaking header!!!!!
Of course, it was easy to be a little cocky about it when the PO had given me an extra 68 head with the truck!
Got any pics?
I would be very interested if anyone has pics of this.
I am seriously contemplating adding the holes to my block - would like all the data I can find.
TIA,
TIA,
The pics would look just like a factory PS setup... they had both blocks side by side and drilled/tapped the ports. Not sure who there machine shop is, but the dealership is Larry H Miller Toyota in Murray.
