for what its worth I'm about to get back to my rebuild and will be tuning my 10mm 1hz pump as close to the 1hz-t specs while making the adjustments for the boost comp (as per 1hd-t spec). pity the 1hz-t didn't have a boost comp! anyway if all goes without a hitch I should be driving around testing in a month, maybe trying a few tuning tweaks depending on how it goes, but none for nail-biting performance, and I will be reporting after that on the results.Define goal?
If it's about like the 12HT is, then I'd be very happy.
I'm not looking to make it into a monster hot rod, just have decent power (to push a 60) up 4% grades at, say 55mph without having to worry about it overheating. That's more important to me than power.
I've got a boost compensator, so that narrows it to two choices:
The diesel shop thinks they can build it to the 1HZ-T specs, which is why I'm asking. If they hadn't said anything I suspect I would have been plenty happy with a rebuilt IP with a boost compensator on it.
- stock 1HZ pump with boost compensator
- 1HZ-T pump with boost compensator
Dan
I'd love to know how it goes if you can get the pump shop to report their numbers
CheersI am not driving the truck anytime too soon (hopefully by this summer maybe), but I'll attach the fuel delivery numbers that the shop picked when we guessed at the settings.
Sorry it's not a great scan, but it should get you started. I will report back when I get to drive the truck, for sure.
Dan
so what will I do? Given i want stock 1HZ-T performance, but that my current 2002 1HZ injectors already live in the newer head and have the slightly higher crack pressure, after all that effort I think I'll just leave them at their designed specs (150-160), but it's nice to no longer have many doubts.
do you agree? anyone have any better ideas?, bare in mind i don't want anything above stock performance and reliability.
great info, thanks
nah, they put them on aftermarket here in Peru, i know one shop that's done a ton for Toyota themselves over the years, they're usually AXT 1HZ kits and they deliver the vehicles new to the clients with turbo from day one, since the 1HZ is practically a sleepy drunken slug by 3500m when driving up from sealevel. in my pre-turbo days, just to keep it running reasonably i'd often be moving the fuel switch on the pump numerous times on trips, one setting for 0-2000m, another for 2000-3500 and another for 3500-5000m.I would guess the peruvian wouldn't install aftermarket Turbos and that she was talking about FACTORY Turbo 1HZ engines made for high altitudes like in Peru.
Caetano Optimo III from portugalI don't think this was ever built for the European market, but rather for places like Peru etc.
Toydiy.com
1993 TOYOTA COASTER (HZB50R-ZRMRXW1)
my cars ▼
STD EUR RHD HRF 1HZT TD MTM5 FIVWOC or LHD
17201TURBOCHARGER SUB-ASSY
17201-170201€ 4,215.17
Would like to know why these can show up with 4300cc opposed to 4200cc
Need to search as incomplete vehicles
Some of these buses came with a six-speed manual tranny behind the 1hdt 1997-1999
JPNWTHRF1HDFTTD4MTM6FCBUWOC29S
| 13101 | PISTON SUB-ASSY, W/PIN | ||
| 13101-17030-01 | STD, MARK 1, REFER REPAIR MANUAL | 6 | € 232.76 |
| 13101-17030-02 | STD, MARK 2, REFER REPAIR MANUAL | 6 | € 232.76 |
| 13101-17030-03 | STD, MARK 3, REFER REPAIR MANUAL | 6 | € 232.76 |
| 13103-17030 | O/S 0.50 | 6 | € 232.76 |
| 13101-17100-01 | STD, REFER TO REPAIR MANUAL, MARK 1 | 6 | $160.22 |
| 13101-17100-02 | STD, REFER TO REPAIR MANUAL, MARK 2 | 6 | $160.22 |
| 13101-17100-03 | STD, REFER TO REPAIR MANUAL, MARK 3 | 6 | $160.22 |
| 13103-17100 | O/S 0.50 | 6 | $192.02 |
| 13104-17010 | O/S 0.75 | 6 | $187.76 |
